A/C Issue
Any idea what may be causing this? I do have an extended warranty, so I will take it in to the dealership this week, just trying to get some advice.
These 3 have all been brought up this week alone about 10 times...there's 3 other threads on this page devoted to this issue.
http://forums.corvetteforum.com/c5-t...errerid=228945
http://forums.corvetteforum.com/c5-t...-changers.html
http://forums.corvetteforum.com/c5-g...errerid=228945
These 3 have all been brought up this week alone about 10 times...there's 3 other threads on this freaking page devoted to this issue.
00....If you don't want to help or if people posting more than once troubles you to where you find it necessary to be rude then don't reply. It's that simple. I get people posting and PMing me with the same questions all the time but I realize how many times others here have helped me so I delightfully oblige and help any person anytime.
Perhaps you should become a moderator.
Yes, when you go WOT, the AC compressor is shut down by the puter.
First off, ALL THREE LINKS WORK
Second, that's the 5th time I've posted links this week to those threads
Third, this is a very common issue
Fourth, What did you contribute to his thread?...nothing
Fifth, ANY OF THOSE THREE LINKS I POSTED WILL HELP HIM FIX HIS ISSUE
The search is here for a reason, if you don't feel like using it. Fine
There's still 2 or 3 other threads with people having the exact same issues in the general and tech section as I write this.
Those stickies and the search feature are a gold mine and can save hours of waiting around or posting back and forth. I have learned so much on forums by going through the top few stickies in the general/tech sections. Most of the "search feature, username search, etc" is all the same on each forum.
I just mean, you can literally narrow a search down to "AC WARM DRIVER SIDE" in the title only. And if anyone else has ever had that issue, they probably created a thread.
Sometimes, your thread ends up dropping to the bottom with no replies due to time zones, seniors not being here atm, whatever. The search can just save so much headache.
I am truly sorry for saying "man" and "freakin" but I didn't think it would be so brutal. We are grown men/women.
Now, to the OP...did you ever get a chance to check your codes?
See if you've got B 0361, B 0363, B 0365, B 0367 or B 0441 and post back
