[Z06] Sporatic engine temp.
Old Jul 24, 2010 | 11:26 PM
zacmac08's Avatar
zacmac08
Cruising
Default Sporatic engine temp.
SO I just took my Z into the dealer to get my transmission replaced, and they also fixed a problem with heat from the engine venting into the cab, but now the engine is shooting around on the dash because of excess heat, what can I do to aleviate this problem?
Old Jul 26, 2010 | 03:20 PM
Yellow95's Avatar
Yellow95
My guess it that it is low on coolant. I had that problem on a previous car. Make sure there is no air in the system. The temp reading will not be right when a bubble goes over it.
Old Jul 26, 2010 | 04:47 PM
krazyKanuck's Avatar
krazyKanuck
Probably low coolant and/or bad overflow tank cap and/or air in the system. Spend the $8 and get a new cap for the overflow tank and go about the business of bleeding / topping up your coolant system. Due to the gravity design of the system, this is an easy procedure, a forum search will give you all the info you need.
To Sporatic engine temp.
