Colum Lock Bypass won’t work
Old Jul 29, 2010 | 06:59 PM
GREENEYEMONSTER's Avatar
GREENEYEMONSTER
Default Colum Lock Bypass won’t work
Just installed the CLB and the steering wheel is still locked, I no longer get the service message; and I just had my battier checked and it is good. What is my nest step?
Old Jul 29, 2010 | 07:12 PM
had2have-it's Avatar
had2have-it
I had the same issue and after some research I found that you can trace down the motor plug (its one of the connectors you unplugged at the factory harness and then replugged to the clb) and send a 12v current to it and in my case it released the wheel. However the clb would not convince the computer all was well and it would still kick in the 2mph fuel shut down. Then I had to trailor the car to a competent tuner who adjusted the fuel shut off feature to 256mph instead of the normal 2mph activation. Google "column lock simulator" instead of column lock bypass. Hope my experience helps you with your problem.
Old Jul 29, 2010 | 09:39 PM
TraceZ's Avatar
TraceZ
I spoke on the phone with GREENEYEMONSTER
He is unable to unlock the steering wheel using the cigarette lighter adapter that Corvettes Of Houston provided with his CLB.
I advised that he should remove the steering column trim, locate the lock solonoid and tap it with a hammer while connecting the cigarette lighter adapter and hope the motor comes to life one last time to unlock the column.
I verified with him that he does not have a K-harness on his car.
Car is an 02 Z06.
Old Jul 29, 2010 | 11:33 PM
Carcass's Avatar
Carcass
The CLB is not designed to repair a locked column-it,ideally,should be installed before your column lock fails.
Hopefully,you can get it unlocked somehow-make sure there's power to the cigarette lighter (no blown fuse),and at the column lock motor end of the adapter cable-if there is,and tapping the motor with a hammer while power is applied won't make it unlock,you've got a real problem.
I'd like to advise you on what to do if that's the case,but I'm not really sure,maybe someone with more insight will chime in...
Old Jul 29, 2010 | 11:36 PM
8VETTE7's Avatar
8VETTE7
with what TraceZ has sugggested. If that fails to work I suggest trying the procedure in the following link. It has worked for most people when the column is locked. You may need to repeat the procedure more than once and do not be afraid to go at the procedure with some aggression.
http://forums.corvetteforum.com/show...ghlight=unlock
Post up if neither of those work. The next steps are more drastic.
Old Jul 30, 2010 | 03:01 PM
GREENEYEMONSTER
I resolved the issue, scrolled through the DIC and the volts were reading 11.6; so I left everything hooked up and started the car for about a minute, and then the column lock disengaged. Thank you all for the help this forum is the best.
Old Aug 12, 2010 | 04:22 PM
Bimmervet's Avatar
Bimmervet
St. Jude Donor '12-'13-'14-'15-'16
Default Steering Column does not Lock
I am getting the same message the car had the recall done. The fuel is cut off as soon as the car moves BUT the steering column does not lock??? Why
Old Aug 12, 2010 | 07:08 PM
teebee's Avatar
teebee
2021 C6 of the Year Winner - Unmodified
It's a very complex issue....here are a couple of videos that help explain things. These are of Paul Koerner, a GM World class Corvette specialist.
Part 1
http://vettetube.com/view_video.php?...25f49408d959ca
Part 2
http://vettetube.com/view_video.php?...3c1a84ce5276e9
Old Aug 12, 2010 | 08:51 PM
Jet-Jock's Avatar
Jet-Jock
This post is a good testament to the primary cause of column lock issues, that being a low or dead battery.
Glad you got it solved.
Be sure to clear the codes too.
Old Aug 12, 2010 | 09:10 PM
Jet-Jock's Avatar
Jet-Jock
Part 1
Part 2
UH these videos should be required watching for every C5 owner.
Old Aug 12, 2010 | 10:21 PM
SCM_Crash's Avatar
SCM_Crash
That cigarette lighter tool burnt the fuses on both of my power ports in my first Z06. The cig lighter tool did work on my second Z06, though. So, like what has been said already, double check the ports to make sure the fuses aren't burnt.
Mean while, what worked for me once was to jolt the steering wheel side to side a couple of good times (in hopes of "squishing" the pin) and then trying to unlock the wheel with the cig lighter.
Old Aug 12, 2010 | 10:34 PM
Jet-Jock's Avatar
Jet-Jock
This is a pdf I found of a majority of AC Delco batteries, specs and prices:
http://www.weaverdist.com/docs/batte...ofessional.pdf
Old Aug 15, 2010 | 12:44 PM
Bimmervet's Avatar
Bimmervet
Tried everything went to dealer they ran the Vin, (since I have owned the car since Nov.) Has all the recalls done the most recent last year when Chev replaced the wiring harness. Dealer says I need to bring it in. Before this happened the steering felt very loose.
This is great since I organized a Caravan to Elkhart Lake ALMS race next Sunday. Don't have time to get my car to the dealer so I will be the bone head driving a Jaguar last car in line of course to Elkhart.
Old Aug 15, 2010 | 01:29 PM
Jet-Jock's Avatar
Jet-Jock
What are the specs on your battery?
Have you had your battery tested?
Old Aug 16, 2010 | 09:03 AM
Bimmervet's Avatar
Bimmervet
Was tested is in spec, only 2 years old.
I am having the car towed to Bill Kay Chev. in Lisle IL. My car has been in for 3 recalls and has the new wire harness. Other friends of mine in the Corvette Club had the same issue, took it to Bill Kay and they disabled the steering wheel lock signal and reprogramed the PCM.
Hope this is all I need.
Had a 68 C3 that I raced for 10 years and the only time something needed to be fixed is when I blew it up, wore it out or smashed it.
Old Aug 16, 2010 | 09:14 AM
Jet-Jock's Avatar
Jet-Jock
I should have been more specific, the battery should be a minimum of 120 reserve capacity, does yours meet that spec? Did you get a chance to watch the video's above?
Old Aug 16, 2010 | 11:18 AM
Good videos. Thanks for the links to them.
Old Aug 18, 2010 | 03:01 PM
Bimmervet's Avatar
Bimmervet
Default Thanks Bill Kay Chevrolet
Now everything works, they had to replace the steering column lock, steering column tilt, rack, sector/lock bolt/actuator rod.
This was all covered under GM Warranty. They took my car in late Monday morning and it was ready for pick up last night.
Thank you Richard Morton Service Advisor
To Colum Lock Bypass won’t work
