windshield lower seal/gasket
Old Aug 1, 2010 | 04:35 PM
KJM813's Avatar
KJM813
Default windshield lower seal/gasket
Can anyone tell me how the rubber seal at the bottom of the windshield is replaced. It appears to fit into a small slot on plastic shroud at base of windshield . It appears to seal the entire bottom edge of the windshield. Mine has partially torn away from the plastic base.
Old Aug 1, 2010 | 07:27 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
It's a trim piece that is attached to the cowl cover.
Give Gene@gmpartshouse.com a call or PM and he can get you what you need.
Old Aug 1, 2010 | 08:10 PM
Jet-Jock's Avatar
Jet-Jock
My windshield was replaced this past Saturday and I know exactly what your talking about. The foam piece is more L shaped and the cleft of the L just sits on the edge of the IP pad. Mine drew my attention because with the windshield out you could see the passenger side is lifting up slightly. Nothing I could do to fix it. Unless it comes out with the IP pad, might be a very tricky install with the windshield in place.
To windshield lower seal/gasket
