Easy question
Old Aug 3, 2010 | 03:20 PM
BOHICA76's Avatar
BOHICA76
Default Easy question
Here is an easy question for everyone. What is the thing that is plugged into the windshield and is connected to the black strip that goes across the windshield. Mine has become disconnected and I am needing some advice on how to repair it. It looks like it connects by solder. Can I use a specific glue instead of soldering back on?
Old Aug 3, 2010 | 03:24 PM
BWF07's Avatar
BWF07
St. Jude Donor '11
Oldtimer
I don't know about you, but mine is the radio antenna, but then again I have an '01. The only other wiring in that area is the wiring for the lights on the rearview mirror.
Old Aug 3, 2010 | 03:25 PM
CatCam's Avatar
CatCam
FM antenna.
BOHICA76's Avatar
BOHICA76
Originally Posted by TR6speed
I don't know about you, but mine is the radio antenna. The only other wiring in that area is the wiring for the lights on the rearview mirror.
That must be it. My radio hasn't been working as good lately.
Old Aug 3, 2010 | 03:26 PM
BOHICA76's Avatar
BOHICA76
I just need to know how to reconnect it now. Thanks.
Old Aug 3, 2010 | 06:27 PM
killain's Avatar
killain
Oldtimer
And there's a kit at most name brand parts stores like NAPA should have it. It works very well and if you follow the directions it is reattached to the glass.
Old Aug 3, 2010 | 07:37 PM
Munch's Avatar
Munch
St. Jude Donor '10
If the actual connector snapped off the trace on the glass you can solder it back on if you're careful and quick. I soldered some broken connectors for the rear defroster on my 01 Monte Carlo and it worked great.
Disclaimer: I have no idea what broke on your car and have no idea if soldering is safe for your specific application.
Old Aug 3, 2010 | 07:41 PM
sneakelman's Avatar
sneakelman
St. Jude Donor '08-'09
Disclaimer to Munch's disclaimer:
Only attempt this if you have glass replacement on your insurance.
Old Aug 3, 2010 | 07:55 PM
tail_lights's Avatar
tail_lights
Originally Posted by CatCam
FM antenna.
Old Aug 3, 2010 | 09:57 PM
BOHICA76's Avatar
BOHICA76
Dr. Girlfriend, lol, it is the connector that broke off. There is still a rectangle with two circles attached to the glass. The other piece also has a metal rectangle with two circles on it so I need a way to connect them back up.
Old Aug 3, 2010 | 10:43 PM
Jet-Jock's Avatar
Jet-Jock
Is your's a Z06, can't tell from your profile?
Do you have an antenna at the rear quarter panel?
Old Aug 4, 2010 | 05:29 AM
FM antenna.
Old Aug 4, 2010 | 02:01 PM
BOHICA76's Avatar
BOHICA76
No Z06. I don't have an antenna at the rear quarter panel.
Old Aug 4, 2010 | 02:15 PM
Jet-Jock's Avatar
Jet-Jock
Opps I should have included FRCs too. Z06's had a fixed antenna and FRCs had the windshield antenna. I believe most auto parts stores carry repair kits.
That is your FM antenna, as some have said.
To Easy question
