[Z06] headlamp make noise after closing
Old Aug 3, 2010 | 07:08 PM
koz06's Avatar
koz06
Default headlamp make noise after closing
My headlamp makes some loud noise for about 5 seconds after closing , i was wondering what is that? Could it be the headlamp motor needs replacement? Thanks 03 vette z06
Old Aug 3, 2010 | 07:45 PM
Ragresen's Avatar
Ragresen
The motor gear is stripping out. you may want to look into the Brass gear replacement for the cheep plastic Factory ones.
Old Aug 4, 2010 | 08:12 AM
uberC5's Avatar
uberC5
Pretty soon, it won't come up when you want it too, and you'll get to open the hood and turn the **** every time you drive at night. I did the gear replacement, but the motors themselves came loose in their housings and made operation erratic. So, to avoid motor replacements and save the OEM lights and relays, I now have fixed projector headlamps.
Old Aug 4, 2010 | 08:27 AM
TDEZ06's Avatar
TDEZ06
Mine was doing the same thing, and I replaced the plastic gear with a brass one a couple of weeks ago...works perfect now!
Old Aug 4, 2010 | 09:08 AM
MTL_Z06's Avatar
MTL_Z06
Great to know!
Mine is doing the same thing on the passenger side!
I guess i will be changing out the gear!
Mark
Old Aug 4, 2010 | 03:01 PM
jcs44's Avatar
jcs44
I recently did this fix on my 03 Z. There are several places where you can buy the repair kits that have the brass or metal gears and the lube and glue needed to put the case back together again after you've pried it appart. The fun part is getting the whole light assembly out of the car and back in again. But the kits work as advertized.
jcs44
Old Aug 4, 2010 | 03:12 PM
Dennis Wilson's Avatar
Dennis Wilson
Originally Posted by MTL_Z06
Great to know!
Mark
I did a quick fix on mine, Remove the linkage that lifts the light from the motor [its on the inside under the light ] & manually turn the **** 180 deg. & put it back on. & you will be using the other half of the gear. I bought the brass gears But haven`t had to use them yet. Been about a year now. It can be done from above, but I did it from below, took about 1/2 hour.
Old Aug 4, 2010 | 08:30 PM
stevedun's Avatar
stevedun
Cruise-In 8-9-10-12 Veteran
This is what I did also. I did also tighten down on the tabs that hold the motor onto the gearbox. It should be tight. Did not like the design on the motor/gearbox tabs, instead of bolted.
Old Aug 6, 2010 | 10:15 AM
koz06's Avatar
koz06
Is that all i have too do? or is there more instructions on how to remove linkage . For example do i have to take cover or remove any thing other than the linkage and turn the **** clockwise or couter clockwise 180 degrees.
Also my cars from canada so if i wanna turn off the automatic headlamps i cant in the dic. Do i have to pull a fuse then? Thanks
Old Aug 6, 2010 | 10:51 AM
Dennis Wilson
No just remove the linkage arm & turn the ****.
Old Aug 7, 2010 | 07:38 PM
stevedun's Avatar
stevedun
So, did you get fixed?
Old Aug 8, 2010 | 10:21 AM
koz06's Avatar
koz06
I am going to look at it today. What are the full details of removing the headlamp handle? Do i have to unscrew it when the headlamps are up and which hinge is it? Thanks
Old Sep 4, 2010 | 09:57 AM
dlboyd41's Avatar
dlboyd41
what is the best way to get to the linkage arm? Thank you i am new to this.
To headlamp make noise after closing
