I have driven it 300 miles and front has came down just a little from these pics. Now need to get alignment and set ride height. The rear should be a tiny bit higher then front i think. I also am suprised i can go over pretty bad areas without bottoming out.
There not really longer but the head and bushing is much thinner. They get the car down to a nice ride height. Actually now the car is lower then pic in front and back. It settled maybe 1/4 inch i am guessing
Originally Posted by Toque
Looking good !
The C6 front bolts, with longer rear bolts really do make a difference over the stock bolt lowering.
great looking car killer -- I'd raise the rear back up just enough to make the tire/fender gap the same front & rear -- that would also add just a touch of rake.
From: Wylie TX --> Less is More, except under the hood !
Looking good !
I thought that's what I said....
Maybe my wording was confusing.... sorry.
As i stated i am getting ride height adjusted when i get the alignment. As for ride i think it maybe a little harsher over bumps, i know my cd player skips alot more.
