Brake pad install question:
Old Aug 9, 2010 | 09:07 AM
burbleflyer's Avatar
burbleflyer
St. Jude Donor '08
Default Brake pad install question:
Preparing for a brake job tomorrow. Braided lines, Hawk HPS pads, drilled rotors and powder coated calipers are all going on my FRC.
One thing I can't find a definitive answer to is which side the front pad with the wear indicator goes. Looks to me like the inside but I just want to be sure. I can't see it on the outside of the disc on the car, but just in case i get them off and for some odd reason there isn't one there I wan't ask here first.
Thanks.
Old Aug 9, 2010 | 09:28 AM
Norwegian-Vette's Avatar
Norwegian-Vette
From: Fredrikstad, Norway - sorry if my english isnt to good...
Hi
From the service manual:
Install new brake pads onto the brake caliper.
The outboard brake pad with insulator installed toward the brake caliper housing.
The inboard brake pad with the wear sensor installed nearest the brake caliper piston.
The wear sensor must be in the trailing position during forward wheel rotation.
Replace brake pads in axle sets only.
Frank
Old Aug 9, 2010 | 09:46 AM
sneakelman's Avatar
sneakelman
St. Jude Donor '08-'09
Originally Posted by Norwegian-Vette
Hi
Frank
And there you go.
Old Aug 9, 2010 | 10:22 PM
burbleflyer
St. Jude Donor '08
Thanks! What i needed.
Old Aug 10, 2010 | 08:03 AM
vette.mix's Avatar
vette.mix
good to know
Old Aug 10, 2010 | 08:17 AM
Ultimate ride's Avatar
Ultimate ride
Just did it. Easy job.
Old Aug 10, 2010 | 08:51 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Thanks.
"INSIDE" always
Thanks,Matt
Old Aug 10, 2010 | 09:01 AM
RSchleder's Avatar
RSchleder
I did my brake system a few months ago, as stated, easy job and the results look and feel great.
Old Aug 10, 2010 | 07:41 PM
retired cop's Avatar
retired cop
How tough are the caliper bolts to get loose?
Old Aug 11, 2010 | 11:40 AM
burbleflyer
St. Jude Donor '08
18'' breaker bar. Takes a bit of oomph and the bolts may be difficult to turn out the rest of the way because of the loctite. Remember to turn the front wheels to each side for better access to the bolts.
I also undid the speed sensors and got them out of the way to prevent damage and get a bit more room. As a bonus, my intermittent "service traction control" light that went on a 79 MPH went away.
Thanks guys! I got it done yesterday.
Old Aug 11, 2010 | 12:04 PM
csexton's Avatar
csexton
Good to hear.
Chuck
To Brake pad install question:
