that terrible seat noise
![](/forums/images/ranks/3k-4k.gif)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
My C5 has always done this so I don't know if that's just the way they are or if its from many happy miles squashing down the seat foam changing the geometry of the seat...but every time my seat moves forwards or backwards it makes a terrible sound as the leather (or whatever "leatherish" material the seats really are) rubs against the plastic pieces and carpet which are in contact with it because the seat is too wide to fit into the place the GM engineers put it. its just one of those things that makes the car sound cheap which it really isn't at all.
I don't use easy entry but I have button 1 programmed for driving position, and button 2 programmed for get out (all the way up, and all the way back) so my seat does this every time I get in or out. just wondering if that's the way C5's were designed, or if that's just something my car is now doing after years of driving...and what might I be able to do about fixing it?
I wish they had made the thing 4" wider, add 1" to either side of each seat so it doesn't rub like this.
I've started adding felt with foam tape to the plastic panels where the seat rubs. but it looks like I can only do this to a few small places where the padding would not be visible, I certainly wouldn't want something like that to be seen.
![](/forums/images/ranks/7k-10k.gif)
Received 2,723 Likes
2018 C5 of Year Finalist
![](https://www.corvetteforum.com/forums/images/ranks/cf15.jpg)
Yep, I have a case of "Vette Farts" as well. I plan to swap out to some better skins and I hope that helps. Either way, please let me know if anyone know of any better aftermarket sport seat foam. I think the OEM foam is partially to blame...
![Ack!](https://www.corvetteforum.com/forums/images/smilies/ack2.gif)
Since I leave my seat in the same position all the time, I tuck a black hand towel in between the seat and the interior trim.
...and a small black washcloth under the console lid.
... and a black bath towel between the convertible top and hatch while driving.
I love my Vette, but face the facts - they ARE built cheap!
![](/forums/images/ranks/11k.gif)
When I had Mrs. Patches' seats out for the audio and insulation upgrade, I liberally swabbed the side of the seat bottom in that area with lots of leather conditioner, although any type of lubricant will probably work. The silence lasted for almost 6 months. I need to reapply for that blissful lack of shrieking seat sound.
Supporting Vendor
Ah...you mean the "farting sound"
This is usually due to the leather material being too sticky. While the side of the seat does have some type of fabric instead of leather where it's supposed to rub, sometimes leather will stick.
![](/forums/images/ranks/100-500.gif)
![](https://www.corvetteforum.com/forums/images/ranks/cf10.jpg)
I use all of the automatic settings for the seat and don't have that problem. I keep the passenger seat about even with the driver's seat, so that is not a problem either. Maybe you have fat-assed passengers!
![*****](https://www.corvetteforum.com/forums/images/smilies/willy_nilly.gif)
![Thumbs Up](https://www.corvetteforum.com/forums/images/smilies/thumbsup.gif)
