Wet Sanding!!!!
Old Aug 11, 2010 | 08:16 PM
mel3535's Avatar
mel3535
Default Wet Sanding!!!!
I had never done any thing like this before, and after a quick research on the internet and some guidance from forum member paul68 i decided to try it out on some of the bigger scratches on my car.
I do not have any pictures of the bigger scratches but it looked like a cat was responsible for them and the last owner did have cats so i am guessing that's what it was.
After wet sanding(2000grit), using rubbing compound and puting wax on it, the scratches are completely gone. It is quite impressive that i could get sratches that were fairly deep.
How ever it is very time consuming work,especially when done by hand. It took very long time and to get the hazed look from wetsanding out of the car, i had to keep on going back with rubbing/polishing compound over and over to finally get it out.
Took me almost 40 min if not more to do two scratches. I will do some more next week and will also take some pics.
This was done by me and paul(paul68) the other day and its worked quite well and you can not even see the scratch now.
Old Aug 11, 2010 | 08:20 PM
Gitusum's Avatar
Gitusum
nice job bro I am guessing you dont have a buffer? that would have cut your time down alot.
Rick
Old Aug 11, 2010 | 09:23 PM
vette54728702's Avatar
vette54728702
Very nice job... though as stated above a buffer would have made it easier... but if it is a high speed buffer you would also have to worry about getting the paint to hot and causing other damage. Good job!
Old Aug 11, 2010 | 09:26 PM
Munch's Avatar
Munch
St. Jude Donor '10
Now do the whole car, it will look like glass!
Old Aug 11, 2010 | 09:28 PM
csexton's Avatar
csexton
Looks great
Chuck
Old Aug 11, 2010 | 10:38 PM
Paul 68's Avatar
Paul 68
Rick
No he doesn't have a buffer, I do but we where just trying some wet sanding out and on a small area seem to work pretty good. If he does alot more wet sanding he going to need a buffer.
Old Aug 11, 2010 | 10:39 PM
tlc0706's Avatar
tlc0706
Good job....Very time consuming and a great danger of a sand through......
Old Aug 11, 2010 | 11:58 PM
gto442w30's Avatar
gto442w30
If the car has factory paint,be careful the factory paint is thin and easy to burn through.
Old Aug 12, 2010 | 12:40 AM
seamus2154's Avatar
seamus2154
B uy the Flex orbital buffer and you'll never look back. lake county orange pads and you'll do the whole car in no time.
Old Aug 12, 2010 | 12:41 AM
Gr8Wht's Avatar
Gr8Wht
CF Veteran
St. Jude Donor '10-'12, '25
Very nice job....I've got to do this in a couple of places!
To Wet Sanding!!!!
