Jack,Which one.
Old Aug 12, 2010 | 09:24 AM
Dale002's Avatar
Dale002
Default Jack,Which one.
I want to buy a jack to raise my car.
However once I add the pad,I can't seem to find one that will go low enough.
What do you guys use.
Old Aug 12, 2010 | 09:38 AM
runner140*'s Avatar
runner140*
Covered in above "sticky". Build a 2" to 4" wooded ramp.
Old Aug 12, 2010 | 09:39 AM
A Marsh's Avatar
A Marsh
I have a low-profile Craftsman Professional that works fine even when using the jacking pucks.
Old Aug 12, 2010 | 09:46 AM
64Corvette's Avatar
64Corvette
Default Jack
I would recommend the XL35 jack from Northern Tools. It is a 3.5ton low profile jack, 3.5 inches at plate and will lift to 21 inches high. cost is 159.00.
Old Aug 12, 2010 | 09:58 AM
Dale002's Avatar
Dale002
Thanks Guys
Old Aug 12, 2010 | 09:59 AM
jellis's Avatar
jellis
i have rhino ramps to park on but if i just want to jack it up w/o the ramps, i pull up onto two small 2x4's i cut and then use the pucks and jack.
Old Aug 12, 2010 | 11:32 AM
runner140*'s Avatar
runner140*
Thats what I use too.
Old Aug 12, 2010 | 11:37 AM
joecaver's Avatar
joecaver
From: 63.8% of all statistics are made up on the spot.
St. Jude Donor '08-'10
I bought an AC Delco last week at O'Reillys Auto Parts that worked great. It fits under the lifting pucks and it's strong enough that I lifted both rear wheels at once from the center.
http://www.oreillyauto.com/site/c/de...0768&ppt=C0373
Old Aug 12, 2010 | 12:02 PM
lake_bueller's Avatar
lake_bueller
As much as I don't like most stuff from Harbor Freight, I picked up a 2T low profile (2 7/8" at lowest level) for $80. It is low enough to get under the Vette yet has enough lift to get my lifted Land Rovers off the ground.
Old Aug 12, 2010 | 01:30 PM
I use a Craftsman aluminum racing jack that has a very low minimum height - it works with jacking pucks in place.
Old Aug 12, 2010 | 06:17 PM
Joe Babe's Avatar
Joe Babe
harbor freight offers a lot of lifting jacks, i got their low profile one.I also have race ramps.
Hope this helps.Joe
Old Aug 12, 2010 | 07:21 PM
Must_Have_Z's Avatar
Must_Have_Z
I've got this one from Harbor Freight:
http://www.harborfreight.com/2-ton-l...ack-67022.html
Super low (2-7/8" min height), 2-ton, and fits under my rear cross member and side frame rails, even though I'm lowered almost 2" on Pfadt coilovers. Love it!
Old Aug 13, 2010 | 10:57 AM
JohnnyT's Avatar
JohnnyT
Yep! Arcan XL35, it's what I have and it rocks
Lifts my rear with no blocks, and all the front needs is a drive up on a 2x4.
Old Aug 13, 2010 | 11:15 AM
Fast Cop's Avatar
Fast Cop
Thats what I have and never had a problem. Low cost and works well.
To Jack,Which one.
