MODS that increase MPG??
Old Aug 14, 2010 | 11:41 AM
ZYa's Avatar
ZYa
The red lights in the bay area suck up the mpgs. Try resetting the avg mpg while on the freeway. Other than that, maybe a dyne tune?
Old Aug 14, 2010 | 11:51 AM
KorbenDallas's Avatar
KorbenDallas
Perhaps have a compression test done on your engine. I had a Ford Probe once upon a time that had a bad head gasket and the MPG kept getting less and less. I sold it when it was getting 22mpg on the highway, then the new owner replaced the head gasket, and it got 30mpg after that.
Do you have white or black smoke coming from the exhaust? The smoke would be most noticeable when you accelerate.
Old Aug 14, 2010 | 01:57 PM
UM Rebel's Avatar
UM Rebel
My '04 CE A4 gets 26 - 27 on the freeway. I installed K&N filter a while back, that seemed to increase milage from 25 - 26 to where it is now. Don't know if was K&N or just time to change the filter.
Old Aug 14, 2010 | 02:24 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
I drive the Atlantic city Expressway, its very flat. I get 32 mpg during that run. In other areas I get 27 or 28 where the highway is not as flat.
Old Aug 14, 2010 | 02:42 PM
bullmarket's Avatar
bullmarket
POSSE SENIOR RIDER
A good tune. I average 21-22 around town and 28-30 highway, unless I'm on it, of course.
Old Aug 14, 2010 | 02:58 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
I have an A4 with 3.15 gears and on the highway with cc set I get about 28-29 mpg, In town I get about 19-20. That is figuring it with gals used and miles driven on a 450 mile trip.
Old Aug 14, 2010 | 03:15 PM
Silver48's Avatar
Silver48
Here's a link to a trip we took in our stock '04, A4, 3.15 rear end Cpe. Included 80 mph speed on I-10, blasting over 100mph at one point and tooling around the Rio Grande river and the town of Fredericksburg, Texas on the way home. I was happy with the mileage.
http://forums.corvetteforum.com/c5-g...road-trip.html
Old Aug 14, 2010 | 04:11 PM
road pilot's Avatar
road pilot
2016 C5 of Year Finalist
My vette has big power and I always get tremendous fuel savings.
I stopped by the local parts store and bought a Burmese Fuel
Snake; put it in the tank and my fuel mileage is great. Try it!!
Old Aug 14, 2010 | 04:17 PM
Mr.Bill's Avatar
Mr.Bill
eBay has them also at a good price.
Old Aug 14, 2010 | 06:15 PM
vettman96's Avatar
vettman96
2000 A4, no mods, and 3.15 gear. 70 mph 30 mpg +-. My range is
near 500 miles @ 70 on cruise. Your mileage sounds very low to me.
Old Aug 14, 2010 | 06:42 PM
Phanni's Avatar
Phanni
I have gotten 30 MPG on a couple of long trips with a 2000 a4 vert.
I don't creep along either.
try some experiments,
fill youu tank
reset the gauges
drive at 70 mph for 15 minutes.
note the RPM's (that'll tell you if the engine is running efficiently
Compare your mileage and RPM's to some of the claims here.
Those RPM readings will be a real clue..
Old Aug 14, 2010 | 09:23 PM
bleeper's Avatar
bleeper
my stock 2000 gets around 28-30mpg with the a/c running on the interstate. fwiw i saw a mod on another website of adding a rear bellypan to a c5 and they saw improvement of 1-1.5mpg with it.
Old Aug 14, 2010 | 09:40 PM
  #33
powderski13's Avatar
powderski13
Your milage diffinately sounds low. I have 700 hp, a 2800 stall TC and Z06 3.42 gears with a FLP Level IV A4 and I still get 23 on the freeway cruising 75 mph with some spirited runs.
Old Aug 14, 2010 | 11:50 PM
  #34
Rebel 1's Avatar
Rebel 1
I have found the DIC to be Completely Accurate on our car.
When i check the average miles per gallon on the DIC versus miles driven and gallons used it always ends up the Same or never more than + or - .2 difference.
Old Aug 15, 2010 | 12:10 AM
  #35
Mr.Bill's Avatar
Mr.Bill
You have to be the only one then. There are too many variables for it to be the same as doing miles and gals used.
Mine always reads more mpg than i actually got.
Old Aug 15, 2010 | 12:45 AM
  #36
itzza427's Avatar
itzza427
Mine too,,,it's usually about 1.5 mpg "happy"!! I think new wires and Delco Iridiums would be a wise investment regardless,,,It can't hurt,,and you would know you are good in that department for a long time in the future!!
Old Aug 15, 2010 | 01:38 AM
  #37
01magnetic01's Avatar
01magnetic01
I think it also depends on the terrain, my stock A4 usually gets 25-26 on the freeway(70mph) 19-20 in town, came back from Petaluma to Sac recently and got 29 going 75-80....go figure
To MODS that increase MPG??
Old Aug 15, 2010 | 02:11 AM
  #38
Rebel 1's Avatar
Rebel 1
Nope and i am not the only one. I have discussed this on the C5 AND C6 forums and there are Many others who have the same results. As i said i check it on the DIC and then against miles driven and gallons used. I use the same gas station and usually the same pump so the readings are Very accurate.
Old Aug 15, 2010 | 02:28 AM
  #39
Choreo's Avatar
Choreo
I have seen the same MPG drop on my car the past couple years. I am now down to 13.5 average. I have new air cleaner, cleaned MAF and Throttle body, new Iridium Plugs with GM red wires.
Next step for me is to try replacing the front O2 sensors to see if that helps. After 10 years they are probably trashed (but no codes).
Old Aug 15, 2010 | 03:46 AM
  #40
mel3535's Avatar
mel3535
i think i run around 1700/1800 rpm around 70 miles, but that's off the top of my head, i will check what exactly it is tomorrow,
what RPM are you guys at at 70mph?
