Corvette Photography *PICS*
www.prestontoddbradford.com
Bill aka ET
Both shot at f5.6 on a fixed 4.5 lens on tripod and off camera flash. The first one:
[Image]
Make = Canon
Model = Canon EOS 40D
Orientation = top/left
X Resolution = 547
Y Resolution = 547
Resolution Unit = inch
Software = Adobe Photoshop CS4 Windows
Date Time = 2010-08-15 14:45:29
Exif IFD Pointer = Offset: 208
[Camera]
Exposure Time = 1/50"
F Number = F5.6
Exposure Program = Aperture priority
ISO Speed Ratings = 400
Exif Version = Version 2.21
Date Time Original = 2010-08-14 18:59:17
Date Time Digitized = 2010-08-14 18:59:17
Shutter Speed Value = 5.64 TV
Aperture Value = 4.97 AV
Exposure Bias Value = ±0EV
Max Aperture Value = F3.51
Subject Distance = Infinity
Metering Mode = Spot
Flash = Flash fired, compulsory flash mode
Focal Length = 30mm
Subsec Time Original =
Subsec Time Digitized =
Color Space = sRGB
Exif Image Width = 1000
Exif Image Height = 667
Focal Plane X Resolution = 4438.356
Focal Plane Y Resolution = 4445.969
Focal Plane Resolution Unit = inch
Custom Rendered = Normal process
Exposure Mode = Auto exposure
White Balance = Auto white balance
Scene Capture Type = Normal
The Second one:
[Image]
Make = Canon
X Resolution = 300
Y Resolution = 300
Date Time = 2010-08-15 14:30:57
[Camera]
Exposure Time = 1/80"
F Number = F5.6
Date Time Original = 2010-08-14 19:05:33
Date Time Digitized = 2010-08-14 19:05:33
Shutter Speed Value = 6.32 TV
Subject Distance = 8.5m
Focal Length = 30mm
Color Space = sRGB
Almost looks like the artificial tilt-shift effect.
Is this that miniature plug in... ? If so it is very cool...
I see that it is, I amswered my own question:
Simulating tilt-shift photography with the Bokeh plugin
by James Dempsey, Macworld.com
In last week’s blog entry on adding focus to your images with Bokeh, I showed you how you can use Alien Skin Software’s Bokeh plugin for Photoshop to draw attention to the subject of your photos by adding and adjusting out-of-focus areas of an image to enhance the subject matter.
Tilt-shift photography simulates the effect of turning your subject matter into a miniature model. You produce the effect through special camera lenses that adjust the image plane via camera movements when taking the photo.
