need help
Old Aug 18, 2010 | 05:46 PM
didntdoit11's Avatar
didntdoit11
St. Jude Donor '12
Default need help
as the title says i need help figuring out tire sizes,
i have a 2000 corvette coupe ,im getting zo6 rims 17x9.5 fronts 18x10.5 rear. what size tires will fit i was planning on going with the stock tire size in the front 265/40/17 front, 305/35/18 rear my local tire stor says they cant find the fronts in that size for the nitto nt555r so they said to try a 275/40/17 would that still give the stance that is recomended if anyone has pics of said sizes on there car please post pics or any words of wisdom would help
or feel free to post your tire size and brand
thank you
Old Aug 18, 2010 | 08:59 PM
road pilot's Avatar
road pilot
2016 C5 of Year Finalist
I don't know the stance your looking for..But.....
Check the diameter of your stock wheels/tires. You will see
the difference between fronts and back. The new tires......
just compare the difference and you got it. You need a min.
of a 1/2 inch higher in back than front, so the computer does not
get confused. Alot of guys run 275 front and 305 rear
depending on offset. Good luck............
Old Aug 18, 2010 | 09:05 PM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
I have the same sizes and use 275/40x17 with 295/35x18 rears.
Kumhos
Old Aug 18, 2010 | 09:09 PM
Old Rotor Head's Avatar
Old Rotor Head
I run, 4th set:
Nitto 555
275/40-17 front and 285/35-18 rear
Z06 rims lowered 1",
warning don't get the 295/45-18 or you'll rub the inner fender well. If your buying from on-line vendor purchase the warranty, $20 I think. I picked up a screw in my new tire and they replaced for $00.00.
Old Aug 19, 2010 | 11:08 AM
1320b4you's Avatar
1320b4you
Default tire size
Tire companies routinely discontinue nonpopular tire sizes as i recently found out getting a spare for my jeep. Try a different manufacturer w/the same benefits of the nitto. I run a 265/40/19 and a 295/35/20 on my '99....just compensate profile f/r in proportion to the stock sizes even when going wider/taller.
To need help
