BrakePerformance.com
Old Aug 18, 2010 | 10:10 PM
CLEAR's Avatar
CLEAR
Default BrakePerformance.com
Anyone tried rotors and/or pads from that site? Im thinking of going with the dimple drilled/slotted rotors and pads.
Old Aug 18, 2010 | 10:48 PM
CurbsEnthusiasm's Avatar
CurbsEnthusiasm
I'd avoid it personally if I did it again. I've had this cricket noise that the brakes make since I've put them on. Everything checks out good yet it still makes the noise and their is also another thread from about a week or two ago where others talk about this issue. Brake performance has yet to respond to my situation.
Old Aug 18, 2010 | 10:55 PM
0331MARINE's Avatar
0331MARINE
From: You know your drunk when you swerve to miss the tree then you realize its your air freshener! Covington Ga
Yeah they make an odd noise. I did some searching on other forums(BMW, Audi , and so on) and found out that alot of guys that have the dimple rotors from other companies have the same noise. I really think its the dimples that cause the noise.
Old Aug 18, 2010 | 11:34 PM
Sargechris's Avatar
Sargechris
Yep--I'm one of the cricket owners... (they make Lousy Pets!)... My research also revealed that this noise is somewhat common on ALL dimpled/slotted rotors--and even drilled-slotted ones.... (as written on various forums)...
The rotors are well made, look good, and stop well... But the noise......UGH!
The QC people at Brakeperformace were nice, but could only say that the "harmonics" of these rotors, and the inherent noise, was normal.... They did not make any suggestions (I had already done about all one can do)...
I'm gonna stay with these rotors for now... but next time: smooth rotors for me!
Old Aug 19, 2010 | 05:37 AM
joecaver's Avatar
joecaver
From: 63.8% of all statistics are made up on the spot.
St. Jude Donor '08-'10
I just installed their dimpled rotors 2 weeks ago along with Hawk HPS pads. So far with about 300 miles on them I do not hear any noise and am pleased with the looks and the stopping power.
Old Aug 19, 2010 | 09:45 AM
jornahow's Avatar
jornahow
I have EBC Ultimax slotted rotors with Hawk HPS pads. The product info says that you can expect some "air noise" from the slots. They make a slight whirring noise in low speed stops. I don't mind it and they are great rotors - way better than the (IMO) crappy AC Delco drilled slotted rotors and ceramic pads I had on the car - horrible brake pulsation problems after few miles with little hard use.
Old Aug 19, 2010 | 10:52 AM
renegad44's Avatar
renegad44
From: This is not a Song, It's an Outburst: Or, The Establishment Blues; Sixto Diaz Rodriguez
I've had both their dimpled/slotted, and just put their drilled/slotted on, and can't recall any noises, don't know if it's because of my loud music , or pipes , but I have not had any noise problem from them. Each time, I've used GM ceramic pads with them. So far, so good.
Old Aug 19, 2010 | 10:53 AM
Sargechris's Avatar
Sargechris
Just for clarification purposes: the cricket-noise is only noticeable when 1) window(s) down; 2) driving in an area that reflects sound (adjacent to fence/wall, under an overpass, or next to another vehicle at slower speeds; and 3) the radio is off!
It's not terrible--just annoying...
Old Aug 19, 2010 | 11:00 AM
alxltd1's Avatar
alxltd1
St. Jude Donor '10-'12-'13-'14-'15-'16-'17
I have their drilled and slotted rotors with GM Ceramic pads. No noise to date with about 700 miles on the set up.
Old Aug 19, 2010 | 11:18 AM
Grim Reaper's Avatar
Grim Reaper
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19
I have their drilled and slotted rotors with Hawk ceramic pads and haven't had any issues. They've been on the car about 6000 miles.
Old Aug 19, 2010 | 02:39 PM
black98c5's Avatar
black98c5
I have their Slotted rotors and run Hawk HP+ pads. No noise or issues with the rotos at all. The HP+ pads can get a little noisy though, as with any race pad.
Old Aug 19, 2010 | 06:11 PM
McRCN's Avatar
McRCN
I have had the same set up for about 6 weeks with no issues.
Old Aug 19, 2010 | 09:53 PM
CLEAR's Avatar
CLEAR
Well half of you say they suck and half say they are fine. I dont want any noise though. Ill be running the brake pads they give for free. Has anyone had a problem with them rusting. Im wondering how long the zinc will last.
Old Aug 22, 2010 | 10:42 AM
CLEAR's Avatar
CLEAR
TTT
Anyone else with problems? Hows the zinc coating holding up?
Old Aug 23, 2010 | 04:43 PM
CLEAR's Avatar
CLEAR
on order....
Old Sep 8, 2010 | 11:45 PM
CLEAR's Avatar
CLEAR
I received them and upon inspection found that the left and right rotors are cut from completely different blanks on the fronts and rears. They have a different grove pattern around the edge of the hub and the fins inside the rotors are completely different design from left to right. I called and complaned. They verified that thats just how they come and offered me a $25 refund. Id like to see if anyone else has noticed this. I do get an air noise which is bothersome. They look nice for now but I have a feeling Ill wish I kept my money and resurfaced the stockers.
Old Sep 9, 2010 | 03:36 AM
Corvette Don's Avatar
Corvette Don
If the thickness and weight is the same then I would not be too worried about it.
To BrakePerformance.com
Old Sep 9, 2010 | 06:43 AM
steve8's Avatar
steve8
Any pics?
I was considering these rotors.
Old Sep 9, 2010 | 08:34 AM
Big Earl's Avatar
Big Earl
Originally Posted by steve8
Any pics?
Me Too.
Old Sep 9, 2010 | 10:12 AM
CLEAR's Avatar
CLEAR
here are pix of the 2 rears side by side.
Notice the grove just outside the hub. Also the shoulder on the edge of the hub is different as well as the cooling fins.
