Can Anyone Help with Identifying Part Numbers?
Old Aug 19, 2010 | 06:49 PM
JM20's Avatar
JM20
Default Can Anyone Help with Identifying Part Numbers?
Hi all -
I just purchased a 1999 Convertible, Black on Black, 6 speed and absolutely love the car! I found this forum and there just appears to be a wealth of information here.
Anyway, I'm hoping one of you can help me identify these two part numbers from GM. (The dealer could not even locate them )
I tried searching but could not come up with any results.
1. Factory Dead Pedal (aka drivers foot rest). The two plastic areas on mine where the bolts go through are busted and he pedal needs to be replaced
2. The stock shifter isolation boot (the boot that goes over the shifter and is held in place with (4) 10mm nuts. I just installed a MGW shifter and they their instructions recommend that you cut out this boot so it fits better with their shifter. Well I accidentally cut it a little big and now am getting a lot of engine/tranny heat coming up through the open area and would like to just replace it.
Any help identifying these part numbers is greatly appreciated!
Thanks and hope to be here often!!
~Joe
Old Aug 19, 2010 | 06:51 PM
03WhiteConv's Avatar
03WhiteConv
Call Gene Culley www.gmpartshouse.com
Old Aug 19, 2010 | 07:00 PM
Mark C5's Avatar
Mark C5
St. Jude Donor '08-'09-'10
Shifter boot 12555226
Old Aug 19, 2010 | 07:02 PM
JM20's Avatar
JM20
Talk about quick replies! Thanks a million!
Old Aug 19, 2010 | 07:56 PM
Mark C5's Avatar
Mark C5
Ok, I have looked and looked and looked and can not find the dead pedal in the parts manual. If anyone finds it I'd appreciate knowing what section it's in. Thanks
Old Aug 19, 2010 | 08:05 PM
GrandSportRob's Avatar
GrandSportRob
I ordered parts from Gene before, call him for the info and a great price..
Old Aug 19, 2010 | 08:20 PM
JM20's Avatar
JM20
I contacted Gene (Thanks 03WhiteConv!) and he literally got back to me via e-mail in like two mintues. Talk about outstanding customer service!
In case anyone is interested...the part number for the dead pedal is: 10330770 @ $30.52, and is the same part number for the C5 & C6.
I also orderd the shifter boot from him.
Thanks again for all the help!
Old Aug 19, 2010 | 08:21 PM
JM20's Avatar
JM20
Mark...thanks for your efforts!
Old Aug 19, 2010 | 10:16 PM
Gene Culley's Avatar
Gene Culley
Premium Supporting Vendor
Thanks for the referrals. I was great earning a new customer and friend.
Old Aug 20, 2010 | 04:29 AM
Gene's the man - if a part is available, he can usually find it.
To Can Anyone Help with Identifying Part Numbers?
