I have a 2000 c5 that is running rich. It seems to be worse when you first start it up. When it warms up it is better. The check engine light is on and my tail pipes are are black and smutty. please help.
Clean you MAF. I had the same issue awhile back. I would blow a ton of smoke out under hard acceleration. I thought I had leaky valve stems, but it turned out to be a dirty MAF. No smoke anymore after cleaning MAF and adding some Restore.
