c5
Old Aug 21, 2010 | 11:24 AM
c-low's Avatar
c-low
Default c5
how would you know if a c5 had a broken driver,s side axle would car still move due to posi ? can this be checked by jacking up drivers side and putting car in gear? and finally does differential cover have to come off and some srot of c clip removed like on other cars or is it basically like replacing a front wheel drive axle that just pops into differential and replacing the nut on end of spindle? had had time to just look at car to study assembly i thought id ask first i work a lot any info would help thanks
Old Aug 21, 2010 | 06:52 PM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
Can't help you.....if you don't get responses her, I would post in the Tech Forum.
