[Z06] Short Shifter installation
Old Aug 25, 2010 | 10:58 AM
turk2gk's Avatar
turk2gk
Default Short Shifter installation
Hey fellow forum members. I'm looking to install a short shifter, and I need some instructions(possibly a link) on how to install it myself. Also is the installation pretty hard? Or is it more time consuming than anything?
Old Aug 25, 2010 | 11:30 AM
hotwheels57's Avatar
hotwheels57
Every C5/Z06 technical question that's ever been asked and answered can be found in the archives.
In C5 Tech, click on search or search this forum (in the red banner). The keywords will determine the results. In your case, the question is the most discussed topic on this site.
Use "installing a c5 shifter" or similar. You'll come up with hundreds of threads, so you still have to do the research. That's a good thing because you'll learn different ideas of issues that may be encountered.
This is just one. Be sure you click on every link within each thread...
http://forums.corvetteforum.com/c5-t...-in-my-c5.html
Old Aug 25, 2010 | 01:32 PM
tlove32's Avatar
tlove32
Here's a great step-by-step write up:
http://www.c5forum.com/diy/hurstdiy.php
Old Aug 25, 2010 | 01:39 PM
MawneeC5's Avatar
MawneeC5
Its a piece of cake. Just be careful getting the big console part out as it is easy to crack.
Old Aug 26, 2010 | 02:13 PM
turk2gk's Avatar
turk2gk
Thank you guys!
Old Aug 27, 2010 | 05:42 PM
Mtnvettes's Avatar
Mtnvettes
You didn't say if you are installing the complete shifter unit or just the shifter itself. In any event, it is time consuming, but well worth it. A critical item is to torque the two bolts and the shifter linkage to 28 ft lbs, with the linkage done last. Make sure you install the pad that comes with the entire unit (or is removed from the existing unit) before you insert the unit. Also, be carefull with the plastic ring that secures the boot to the console, it can break. If you are installing a C6 shifter, you will need another boot or trim the existing one. Instead of installing the short throw shifter, I removed the Hurst from my Z06 and installed the OEM - like it a whole lot more and it brings the Z06 back to stock.
To Short Shifter installation
