02' Z06, with 90k miles. I was leaving a red light and it gave out at around 30 mph. I felt a huge loss in power and heard a tapping noise from the motor so I shut the engine off and coasted to a parking lot. I took off the valve covers and this is what I found:
If it were me, Id try to air up the cylinder maybe with a portable air tank and change the bad spring. Get it home, then change all the springs, retainers/keepers and even the valve seals.
Of course, youll need the valve spring compressor tool and the whip hose to air up the cylinder as well as a new spring and retainer/keepers.
Looks like the Valve keepers came out. You may also have Head & Piston damage
Maaaan I hope not, I have been so sick of this car lately. Seems like everything falls apart after 80k miles. I have had this car a year and already replaced:
brake rotors
brake pads
radiator
radiator endtank
tires
A/C compressor,orifice tube, accumulator
battery
I'm probably forgetting other things...
Things that still need fixing:
oil pressure sender
windshield washer pump
center armrest (material split down the middle from heat?)
That is just basic maint. If this was your old E36 M3 you probably would have spent close to the cost of your Z06 on maint by now lol
brake rotors
brake pads
radiator
radiator endtank
tires
battery
oil pressure sender
Actually, I want to say I spent less on maintaining the M3 for the entire time I had it than I have on the Z06 in the year I have had it...
Consider yourself lucky and in the minority then. There is a reason the value of European car values drop off a cliff when they are close to being out of warranty or out of warranty. Repairs are expensive!
I don't think I fixed anything on my BMW that cost less than $100! At least I don't have to worry about interior door handles breaking off in my hand or plastic water pump impellers going out like clockwork at 60k miles with the Z lol
Aren't those aftermarket springs already? They are not the factory yellow beehive springs, unless im blind. If I were you I would boroscope that cylinder to see if you have any piston damage then then do a leak down test on that cylinder.
What should I do next?
sorry , but that pic does not look good. the retainers came out and the valve took a dive into the combustion chamber. hopefully its ok. best of luck.
Got a call from the shop, valve is definitely bent.
Look on the bright side. Now you can bolt on a set of AFR's and never look back. Later down the road you can do a cam and all the bolt ons too. Now bust out that credit card, your on the way to 450 rwhp
