Air Conditioning: Freon recharge?
Old Aug 30, 2010 | 04:06 PM
Z06ster's Avatar
Z06ster
Default Air Conditioning: Freon recharge?
Hey Fellas... My '02 C5Z doesn't seem to have the super cold air she once did. I suspect its just the normal freon escape since it's an 8 year old car. I was wondering if others out there had to recharge their system with freon. Thanks
Old Aug 30, 2010 | 04:10 PM
chris308's Avatar
chris308
I had mine done about a month ago.
Old Aug 30, 2010 | 04:18 PM
killain's Avatar
killain
Oldtimer
Default Cool air.
Your car takes R134 coolant, but your better off taking to a A/C shop where the shop can put a vacume on your a/c system and if it's doesn't have any leaks they can then inject a dye that turns a color when it's leaked to the open air. they would then fix the leak then charge the system with R134 and you'll feel the difference. I did !
Old Aug 30, 2010 | 04:51 PM
Ultimate ride's Avatar
Ultimate ride
I just had my a/c compressor replaced as it was leaking between the halves. What a difference!
Old Aug 30, 2010 | 06:39 PM
Oldvetter's Avatar
Oldvetter
There are two main problems with C5 A/C systems. Actuators can be bad or need reset and the freon can be low. When freon is low, the passenger side is usually cool and the driver's side is warmer.
To Air Conditioning: Freon recharge?
