Hood seal
Old Aug 31, 2010 | 08:27 AM
robsc501's Avatar
robsc501
Default Hood seal
Hi There,
I'am looking to buy a hood seal to keep out dirt & water off my blackwing.I was wondering if anybody has the a/zone part number or Lowes number or GM number?
robsc501
Old Aug 31, 2010 | 09:22 AM
jrose7004's Avatar
jrose7004
There's not a part number. It's just a short piece of weather strip cut to fit and stuck on.
Old Aug 31, 2010 | 09:30 AM
tomringo's Avatar
tomringo
From: Richmond VA Everyone should have a VetteGuard
You can see it on Ecklers Web Site, just search "hood seal" I think its $15.99 for a C5.
Old Aug 31, 2010 | 10:36 AM
You can get a piece of auto weatherstripping at any auto parts store at one of the forum vendors.
Old Aug 31, 2010 | 10:49 AM
99 VET's Avatar
99 VET
Oldtimer
St. Jude Donor '13
Don't have a part # but go to any home center weather strip dept & you will find what you want. Suggest you clean the area with alcohol b-4 installing. I cut a larger piece then needed & dry fitted it b-4 cutting to size. Suggest u put the sticky side down so that when u close the hood the hood is pressing on the weather strip. Good luck!
Old Aug 31, 2010 | 10:58 AM
bhc99's Avatar
bhc99
2nd Gear
zip-corvette.com has it performance hood seal x-777.live in richmond near zip got one saturday 15.95 easy install good quality.
Old Aug 31, 2010 | 01:42 PM
$$$frumnuttin''s Avatar
$$$frumnuttin'
From: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
also, there is enough room to put 2 pieces side-by-side to really prevent any water from getting at the filter from anywhere in the middle of the hood. the second piece will go over a few screw heads, but with good prep it will stay in place well...I was not satisfied with just 1 piece, but adding the second one did the trick.
Old Aug 31, 2010 | 02:48 PM
robertlthomson's Avatar
robertlthomson
Interesting idea! Now that mine has been on for a few years and a little "squished" a second one is not a bad idea. All the kidding and funny comments aside, I really like how this simple mod has kept the engine bay cleaner.
Old Aug 31, 2010 | 02:51 PM
robsc501's Avatar
robsc501
Hi There,
Thanks c/f members for all the replys. I bought this item at a/zone.
Bulb style weather strip 7/8"x 3/4"x 8' Passed the dollar bill test.
Auto zones p/number is MW 78348 $14.99
robsc501
Old Aug 31, 2010 | 03:44 PM
rickko's Avatar
rickko
Here is a link to info on the GM seal. Its really nice because it exactly matches the factory fender seals. It's more expensive than most after market seals but some of the less expensive after market seals look out of place because they are bigger and more bulky looking.
http://dana60.com/rickko/corvette/HPseal/
..rickko..
Old Aug 31, 2010 | 05:14 PM
robsc501's Avatar
robsc501
Hi There,
Thanks rickko.I saw that seal by doing a search on the forum.Nice looking.When I was using the search feature I saw Bill Curlee had a picture of it where he installed it around the trunk. He stated in his post that this p/n 1040-4247 was for a hood seal for a c6. Looked like it came from the factory on the trunk area.
robsc501
Old Sep 9, 2010 | 02:12 PM
SDLong329's Avatar
SDLong329
Searched the p/n through Gene's website ... comes back as 1997 - 2004. Funny ... it has C4 on the label as well!
Old Sep 9, 2010 | 06:35 PM
robsc501's Avatar
robsc501
Hi There sdlong329,
I clicked on ricco's link & saw the m34-117-c4. You are correct it is for a c4 hood seal. B. Curlee must have made a typepo error in his earlier post.
thanks
robsc501
Old Sep 9, 2010 | 08:08 PM
Double D Mods's Avatar
0Double D Mods
Former Vendor
St. Jude Donor '12-'13
Have them
11.99
http://www.doubledmods.com/c5-Corvet...?categoryId=-1
Old Sep 9, 2010 | 08:17 PM
RDS_VETTE's Avatar
RDS_VETTE
Regardless of what you use, it works. Keeps everything under the hood cleaner. Got mine from Mid America $15. Looks like doubledmods has the best deal though. Same thing basically.
http://www.mamotorworks.com/corvette?frame=1.5
Old Sep 9, 2010 | 08:27 PM
SDLong329's Avatar
SDLong329
Hi There sdlong329,
... but the p/n comes back as 1997-2004 (C5). Perhaps it was originally produced for the C4, was used on C5, and possibly also being used on C6?
Old Sep 25, 2010 | 01:41 PM
SDLong329's Avatar
SDLong329
...Autozone ... Bulb style weather strip 7/8"x 3/4"x 8' Passed the dollar bill test. Auto zones p/number is MW 78348 $14.99
My local A/Z had 3M Rubber Weatherstrip, p/n 08650 ... 7/8" thick x 3/4" wide x 8' (you need less than 4' per hood) ... priced at $20.99.
My local PepBoys had similar size seal, 10' length @ $29.99 (ouch).
I looked at the GM seal ... but it did not look like it would get the job done as well as a thicker seal.
To Hood seal
