View Poll Results : What have you done?
Nothing. I like how the DRL's look
70.59%
I pulled the #2 fuse with no ill effects
17.65%
I pulled the #2 fuse, but had ill effects
0
0%
I put a jumper in place with no ill effects
5.88%
I put a jumper in place, but had ill effects
0
0%
I put an isolator on the relay with no ill effects
5.88%
I put an isolator on the relay, but had effects
0
0%
POLL and Questions regarding disabling DRL's
Aug 31, 2010 | 01:34 PM
Ok so I looked and found 3 ways to do it:
Pull the #2 fuse under the hood
Put a jumper in the Relay #38/40 spots in the fuse box located in the passenger footwell
Put isolator in place after removing the dust cover of the relay and reinstall (still not 100% on how to do that
I pulled my #2 fuse. I dont care about the alarm light or the drl's being out due to this. All will throw codes for DRL's being out....
Please list pros or cons to doing this. I alsoadded a poll to see what others have done. Thanks.
Aug 31, 2010 | 01:36 PM
Depending on how sloppy your E brake is, you can pull to first click to turn them off as well.
Aug 31, 2010 | 01:38 PM
Quote:
Originally Posted by
VinnyT
I agree, but the thought of riding with the ebrake engaged even if its one click is a no go for me.
Thanks for responding
Aug 31, 2010 | 01:39 PM
St. Jude Donor '09 thru '26
the jumper is an easy to create item and even easier to install and be done with it.
Aug 31, 2010 | 02:00 PM
Mine are disabled by jumping the relay. I would of rather kept them but they had to be disabled to pass the UK test.
Aug 31, 2010 | 04:57 PM
From: Wylie TX --> Less is More, except under the hood !
I don't see the option for ---> Installed Switchback LED's in place of DRL's.
Aug 31, 2010 | 05:55 PM
St. Jude Donor '08
Toque
I did the same but the switchbacks still act as a yellow drl...was hoping they would act as a white drl.
Aug 31, 2010 | 06:10 PM
That's how I spot 'em comin' at me... they look cool.... leave 'em on!
Aug 31, 2010 | 06:12 PM
They've never bugged me so I left them alone.
Aug 31, 2010 | 07:36 PM
I pulled 38 & 40 DRL relays in the passenger footwell fusebox. Removed the cover on each relay and put a piece of paper/card inside to block points. No codes and DRLs do not work. I tried jumper method, but got codes.
my 2 cents
Aug 31, 2010 | 09:02 PM
00vettefan
The "Look at me and write me a speeding ticket" DRLs have been disabled since the second week I had Ol Red. No tickets, either!
The approach lights work with this method but do not with the pulled fuse.
Aug 31, 2010 | 09:05 PM
I can't see them while I'm driving so I don't care.
Aug 31, 2010 | 09:12 PM
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Switchback LEDs here. I like the safety of the drl.
Aug 31, 2010 | 11:29 PM
DRL's melt those front housings,I dont miss em at all! My black outs look much better without them also!
Aug 31, 2010 | 11:42 PM
Pulled fuse no codes yet been over a month I like my blackouts I don't want my car looking like every pontiac i pass. Dare to be differant
