Techometer
Old Sep 1, 2010 | 04:30 PM
thom w's Avatar
thom w
6th Gear
Default Techometer
Need a little help
While driving along my tech starts jumping up and down, any ideas on how to fix this?
thanks, Thom:
Old Sep 1, 2010 | 04:34 PM
50th_Vert's Avatar
50th_Vert
stop revving your engine with the clutch pushed in???
Tachometer... btw sorry i couldnt help
Old Sep 1, 2010 | 04:53 PM
CBackous's Avatar
CBackous
Originally Posted by thom w
Need a little help
thanks, Thom:
Possibly a crank sensor issue? I would think it would cause other issues as well... but that is the first thing that came to mind.
Old Sep 1, 2010 | 05:10 PM
thom w's Avatar
thom w
6th Gear
Thanks, Is that a loose wire issue per chance?
Old Sep 1, 2010 | 05:16 PM
50th_Vert's Avatar
50th_Vert
CPS crankshaft positioning sensor yes its a sensor on a wire that plugs into your block. is your car throwing a code???
Old Sep 2, 2010 | 01:11 AM
whitehooptie's Avatar
whitehooptie
Check your battery and/or alternator. I'm new to the Corvette side of things, but have been doing Camaros for a long time.
Old Sep 2, 2010 | 12:40 PM
thom w's Avatar
thom w
6th Gear
No it is not giving me a code, I will check the wiring for a loose connection. Thanks
To Techometer
