When I first bought my vette, I wanted to get fresh everything for it, that included brand new pads.
Well, I had the pads replaced not knowing that the ones I had on were still like 70% new.
My question is, now that Im due for a pad change, can I re-use the "old" (70% pad life left) ones that I got back from that first replacement or would that not be a good idea?
I would be certain to burnish the pads immediately after installation. Up to 30 mph then full stop, don't lock brakes, do that for a total of 20 times. Then let them cool and they'll be ready to use. This is valid when you install any pad, new or used.
sorry everyone but i would not. the old pads may have a different wear pattern in them preventing them from having 100% contact to the rotor. seems like it would take more than braking a few times to seat them correctly. i have been told by the pros that you should take a thin cut on the rotor and install new pads. personally i would not want take a risk when it comes to brakes just to save a few bucks.
if someone can explain this otherwise, i would like to hear. again, just my opinion..
Thats the logic I was using behind my question, hence why Im asking, I wasnt 100% sure...
I should say that my rotors are like glass though....
After about 20 hits on the brakes you will be RESEATING them yourself
If you had 70% left on your tires and they weren't dry rotted would you toss them. Hell No. Get another 30K out of your "old" pads.
The front ones wear, the rear ones wear very much LESS.
BIGHANK
said sand the rotors... no problem sanding the rotors at all// you csn also sand the pads Especially if they are glazed, but you can take the glaze off the rotors as well..but do them in a circular motionyou can sans the rotos with the dame grit... place the paper on a flat surface and press down while movi9ng them around, once the surface is uniform you are done..
