Rear end noise???
Old Sep 1, 2010 | 08:53 PM
427TTA4's Avatar
427TTA4
Default Rear end noise???
Okay heres the story I've owned my c5 since it had 60k on it now it has 100k and my Torque tube is going out.That I know I can fix and I know what are the symp. but on the other hand the other day I moved it and when I was trying to take off easy I heard this grinding noise like all the way in the back.My first impression was WTF my first though was that the rear diff is giving out but once I take off no more noise???Its like it runs perfect well in the end if its bad im out like 1k but on the other hand 4.10's are going in if its bad.Just wanted to see what you guys think it is before I empty my bank acount.Thanks for looking.. ps (Anyone have a rear diff for sale lol)
Old Sep 1, 2010 | 10:07 PM
tricep's Avatar
tricep
St. Jude Donor '09
May as well just empty your bank account now...
Your'e going to anyway.
The "rear end noise" in my Z ended up costing about 5K and some change.
Old Sep 1, 2010 | 11:55 PM
seamus2154's Avatar
seamus2154
A brand new GM rear is only 1600 dollars. Rebuilding is silly unless you need to be overbuilt due to mods.
Old Sep 2, 2010 | 12:28 PM
427TTA4's Avatar
427TTA4
But if it was the rear end wouldnt it make noise all the time???
Old Sep 2, 2010 | 12:37 PM
Tim01Coupe's Avatar
Tim01Coupe
When was the last time you changed the rear diff fluid with slip additive?
Old Sep 2, 2010 | 12:48 PM
T5Mika's Avatar
T5Mika
I got a similar question about my A4, but I think the noise comes from the front. I only hear it top down when it reflects from concrete walls etc. There no noise when the engine idles, but when I give it a little gas it starts. I don't think it matters if it's on gear or not. It's been there as long as I've had the car, so I don't know if it's normal.
The noise is kind of scraping or grinding, not squealing like a belt, or ringing.
Old Sep 2, 2010 | 03:38 PM
tricep's Avatar
tricep
St. Jude Donor '09
Supposedly, but not necessarily...
Old Sep 2, 2010 | 05:35 PM
427TTA4's Avatar
427TTA4
(Whats that???)Guess that answeres your question....I never even toched it to tell you the trutt because for the last two years I barely put 1000 miles on it I know the first year I put like 30,000 lol but after that year it was just parked....
Old Sep 2, 2010 | 06:19 PM
Tim01Coupe's Avatar
Tim01Coupe
I used Red Line synthetic 75W90 High Performance Gear Oil (2- qts, until it runs out the check plug) and one bottle of their Friction Modifier (also synth. put this in, between oil bottles so you have room) There are posts here on how to do it, if you can't find them, I can help you find them. Get the rear end in the air (level), drain it, and with a Harbor Freight $4 pump, get the new stuff into it. It's a 50k mile duty and when you mention possibly intermitent noise, this may be the source. Basically an oil change, except pumping oil upwards!
Check your manual for GM spec for other brands, but I am swearing by Red Line.
Old Sep 2, 2010 | 06:24 PM
Tim01Coupe's Avatar
Tim01Coupe
C6 posted in the C5 section, it's basically the same.
http://forums.corvetteforum.com/c6-c...s-for-faq.html
Old Sep 2, 2010 | 06:31 PM
Tim01Coupe's Avatar
Tim01Coupe
This is the friction modifier, 4oz, do not change diff fluid without some sort of GM spec modifier with gear lube:
http://www.summitracing.com/parts/RED-80301/
Old Sep 2, 2010 | 06:57 PM
Jet-Jock's Avatar
Jet-Jock
I'd do a fluid swap first with additive and see what happens.
Old Sep 2, 2010 | 07:02 PM
KorbenDallas's Avatar
KorbenDallas
Try a fluid swap, but it's probably too late for it to do anything. Start looking into differentials
To Rear end noise???
