Lost ABS pump
Old Sep 2, 2010 | 09:57 PM
scarinjo's Avatar
scarinjo
Default Lost ABS pump
Found out from my mechanic that my 02 Vert's ABS pump needs replacing and usually when the pumps go you have to also replace the module. New pump and module with labor will cost me almost 4,000. Can you and where can you get a refurbished pump. I found the module on ABSFIXER but can't seem to locate a pump.
