Side trim removal
Old Sep 3, 2010 | 02:24 AM
AZhitman's Avatar
AZhitman
Default Side trim removal
2001 Vette, Navy Blue... Has the factory side trim, and I don't like it.
However, I'm worried that if I remove it (even meticulously), it'll be obvious.
I guess I wouldn't worry if it was white or yellow, but I'm concerned there might be a difference in the paint color UNDER the trim.
Any thoughts? Has anyone here removed theirs after several years?
(I'll admit, I really want to replace the trim with a set of the side gills, or just leave it blank...)
Old Sep 3, 2010 | 11:09 AM
rickko's Avatar
rickko
You'll never know for sure since everyone's vette has had different exposure to the elements over the years so, my suggestion is to remove the small piece in front of the door. Clean up the area where it was removed; polish, wax, etc. If you see a difference in the paint coloring, get some of the tape used to apply it and put it back.
..rickko..
Old Sep 3, 2010 | 11:48 AM
97Cruzr's Avatar
97Cruzr
8th Gear
Just removed mine last month on a used white 97. Can't tell anything was ever there.
rickko's suggestion is an excellent idea, and exactly what I did.
I used 30lb test monofilament, others have used dental floss.
Old Sep 3, 2010 | 12:17 PM
BWF07's Avatar
BWF07
St. Jude Donor '11
Oldtimer
..rickko..
Old Sep 3, 2010 | 12:37 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
I agree with what the others have said, When I did mine I had an extra set of hands to pull the molding back a bit as I took the fishing line and cut away, It didn't take long to remove them, I did buy a heat gun and it really helped, The hard part was removing all the leftover tape.
Before shot
Old Sep 3, 2010 | 02:02 PM
dougbfresh's Avatar
dougbfresh
If the car has ever been painted and they did not remove the trim you'll have a problem.
Old Sep 3, 2010 | 02:11 PM
buddyfew's Avatar
buddyfew
Default trim removal
use a hair dryer and 3m adhesive removal . i did this method and only needed my finger nail. as for the 'gills' ............well that might impress the high school boys.
Old Sep 3, 2010 | 03:49 PM
1320b4you's Avatar
1320b4you
Default side molding
Wish i could take mine off but the car was repainted w/them on so i'd be up a certain creek w/o a paddle..good luck and the molding-less look is soooo much better.
Old Sep 3, 2010 | 09:29 PM
That's the best way to see how it might look.
Old Sep 3, 2010 | 10:10 PM
vette.mix's Avatar
vette.mix
Before shot
Hey Mr Bill, if you would have left the BSM's on, you would not have that hole in your door now BTW did you get that fixed yet
Old Sep 3, 2010 | 10:36 PM
Mr.Bill's Avatar
Mr.Bill
LOL, No I am still dealing with her insurance. Soon I hope.
Old Sep 4, 2010 | 02:54 AM
AZhitman's Avatar
AZhitman
Thanks Bill.
OK, that does it - I'm gonna take a crack at it on my next free weekend.
Old Sep 4, 2010 | 03:10 AM
Mr.Bill's Avatar
Mr.Bill
If I had only kept my side molding on...
To Side trim removal
