front lowering thread?
Old Sep 3, 2010 | 11:47 AM
ssidekickbp's Avatar
ssidekickbp
Default front lowering thread?
I want to lower my front a bit more on the stock bolts. Can someone please post pics of exactly which bolts I loosen/Tighten? Or is there a good thread? I do not want to screw anything up. The rear end I already have lowered, but I want the front down a little more. Thanks
Old Sep 3, 2010 | 12:12 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
http://www.frankhunt.com/FRANK/hobbi...5_Lowering.htm
1 on each side.
Old Sep 3, 2010 | 12:21 PM
ssidekickbp
Bill you always come through for me! Thanks
now do I tighten or loosen to lower?
Old Sep 3, 2010 | 12:24 PM
Mr.Bill's Avatar
Mr.Bill
1. With the car safely raised and on jack stands and the front wheels removed, find the end of the transverse leaf spring next to the shock. Locate the 10 mm end of the ride height adjustment bolt. It has a retainer clip.
Front Before2. With some suspensions (like the F45) it is easier to get at the top of the bolt if the lower shock absorber bolts (13 mm) are removed so the shock can be moved out of the way.
3. Using a 10 mm socket on the top of the stud, turn counter-clockwise (like unscrewing - even though you are not, you are just on the opposite end of the bolt so it looks that way) until tight.
4. Back off the bolt about a 1/8 to ¼ turn to ensure it does not freeze in place in case you want to raise the car at some future date.
Old Sep 3, 2010 | 12:25 PM
Mr.Bill's Avatar
Mr.Bill
Read the link I posted, It will help.
To front lowering thread?
