Lowering pro's and con's
Old Sep 8, 2010 | 01:22 PM
Sinister-one's Avatar
Sinister-one
Default Lowering pro's and con's
Okay guys lets have your opinions on lowering.....
I ask this as I have a 2000 FRC with C6 Z06 style wheels on it. The rears are 19x11's and the tire is pretty much even with the fender lip. If I lower the car, will I have issues with the tire hitting the fender ?
Your opinions......
Old Sep 8, 2010 | 01:30 PM
dougbfresh's Avatar
dougbfresh
Been beat to death, use the search function.
Old Sep 8, 2010 | 01:42 PM
CBackous's Avatar
CBackous
the only con is you have to keep a better eye out for dips/pot holes
Old Sep 8, 2010 | 01:44 PM
50th_Vert's Avatar
50th_Vert
the 11's will rub under heavy cornering if lowered all the way on stock bolts or even on lowering bolts, yoll be fine.
Old Sep 8, 2010 | 02:21 PM
Sinister-one
here we go again...... if you didn't like the question / thread, then keep your .02 cents to yourself !
Old Sep 8, 2010 | 02:23 PM
Sinister-one
how about only lowering the car a couple of inches ? Will that save my fenders ?
Old Sep 8, 2010 | 02:24 PM
Sinister-one
that everyday driving here in Texas !!
jetmech09's Avatar
jetmech09
lowered on stock bolts with 19/20 no problems
Old Sep 8, 2010 | 02:25 PM
Sinister-one
what's the width of your rear wheels ?
Old Sep 8, 2010 | 02:33 PM
dougbfresh's Avatar
dougbfresh
And this adds something USEFUL?
Old Sep 8, 2010 | 02:37 PM
Sinister-one
as does this ???
Old Sep 8, 2010 | 03:03 PM
Simonmcnasty's Avatar
Simonmcnasty
Im about as low as i've seen....road kill and potholes are the only cons,.......but worth the extra effort for the look!
Old Sep 8, 2010 | 03:07 PM
Sinister-one
what size wheels do you have ?
Old Sep 8, 2010 | 03:53 PM
memphis_vette's Avatar
memphis_vette
lowered on 18/20...295 rear tire
Old Sep 8, 2010 | 03:58 PM
Munky's Avatar
Munky
Your opinions......
I have a 1999 FRC with ace slick z07's - 11" rear as well. I used a lowering kit for front and rear only because my front bolts were seized and needed to be replaced. I did not slam the car, but left around 1.5- 2" inch clearance front and back. Love the look/stance, and have no issues other than the need to pay close attention to inclines, and dips... but if you drive a vette you are going to do this anyway. Do a search on me, and there should be a picture of my car out there - should look the same as yours but in a faster color - pewter
I am also running 305 in rear with no issues.
Old Sep 8, 2010 | 04:01 PM
Sinister-one
rear rim size ?
Old Sep 8, 2010 | 04:02 PM
Munky's Avatar
Munky
http://forums.corvetteforum.com/c5-g...-opinions.html
to save you some effort...
To Lowering pro's and con's
Old Sep 8, 2010 | 04:22 PM
Sinister-one
I had already found your post. Car looks really good ! And I was thinking about doing the same thing you did, leaving about 2" of clearance. I think that's going to be the stance I'm looking for.
Only difference is my rear tires are 325 30 19's.
Old Sep 8, 2010 | 04:43 PM
Munky's Avatar
Munky
Thanks, I am very pleased with the look, and how i turned out. It doesn't look slammed, but is much different than the stock ride height. 325's on the rear??? Hmmm... my 305's are a tight squeeze .. not sure how the 325's will work.
you will need to find an in ground alignment rack to straighten you up once you lower it. I found one here near Richmond (only one) and didn't take that into consideration prior to lowering. I used 01 z06 specs for alignment.
Old Sep 8, 2010 | 05:43 PM
SFL_driver's Avatar
SFL_driver
I believe if you lover on stock bolts you can only lower 1 in, With lowering bolts you can get a little more but there are only 3-4 in before you fit the pavement
