I had an eight hundred mile trip last weekend. This was the first trip that I used my GPS in the FRC. The speed on the GPS was about 3-4 mph higher than my speedometer. When driving a safe speed on the speedometer the GPS shows the speed in a range that could result in a personal visit with a LEO. Which would you place more faith in, speedo or GPS? Thanks guys.
I am believing the GPS. I can see a 1 to possibly 2 mph difference at most between the HUD and the GPS on mine but most of the time it reads exactly the same. I would guess the difference is due to rounding.
With stock wheels and stock size (non runflat) tires the GPS, HUD and analog speedo are all within 1/2 MPH. Sound like you need to get a tune (professional or Diablo or Hypertech, etc.) to adjust for non-std wheel/tire size.
Thanks guys. I forgot, I do have 19s on the back. I bought it that way, so I need to get this fixed as I only use the GPS on trips. I figured the GPS to be the most assurate.
Back when I'd changed my 3.23's out to 3.73's in my Trans Am, I knew I was 15% off for the most part. But on long trips, I used a GPS as my speedo since I never got around to updating the computer with the right gearing.
I had an idea about how to make the computer automatically recalibrate the speedo via a GPS check on regular intervals... I'm sure at some point the manufacturers are going to do this anyway.
The GPS uses multiple satellite info to determine location and speed. The speedometer uses an input from the car itself to determine speed. If you change any parameters, such as tire diameter, rear axle ratio, etc., and don't let the computer know, the final determination will be skewed. With satellite info, nothing matters except rate of movement of the vehicle, as determined by that multiple satellite info fed into, and calculated by, the GPS.
Ed
