Radiator overflow tank
Old Sep 12, 2010 | 07:04 PM
soggysailor's Avatar
soggysailor
Default Radiator overflow tank
I have an older C5. The inside of the overflow tank is so dirty/stained that you can't see through it to see the coolant level. Is there a way to clean this?
Old Sep 12, 2010 | 07:09 PM
Jistari's Avatar
Jistari
Probably
But I wouldnt do it in the car. It comes out easily, two or three 10mm bolts (look for the one under it on the engine side towards the back). You could record the level before you start, clamp off the two lines, remove the tank and steam it or whatever, refill with dexcool to level (or whatever you are using) and reinstall.
Good luck
Old Sep 12, 2010 | 08:38 PM
soggysailor
Car has 176,000 miles. It gets regular coolant changes.
I don't need advise on removing it......
I'm looking for a way to clean it!
Old Sep 12, 2010 | 09:06 PM
ALLEGRO's Avatar
ALLEGRO
"If" you can successfully remove it, you can fill it full of soapy water and ice cubes so dislodge the grit and grime in there. I have done this with coolant reseviours as well as plastic brake and clutch res's as well.
Good luck, let us know how it all comes out.
To Radiator overflow tank
