Header Installation Question
Old Sep 12, 2010 | 08:49 PM
atmsrus1's Avatar
atmsrus1
Default Header Installation Question
I bought a set of headers and x-pipe for my C5 and was wondering if I put them on myself how high does the car need to be off the ground. I don't have a lift so I will be doing this the old fashioned way, on my back...LOL
Thanks,
Russell
Old Sep 12, 2010 | 08:55 PM
6 Shooter's Avatar
6 Shooter
DUDE - Find a garage somewhere!
L8TR - D
Old Sep 12, 2010 | 08:57 PM
MagRedConv's Avatar
MagRedConv
There are at least two current header install threads in the Tech section.
Old Sep 12, 2010 | 08:58 PM
n8dogg's Avatar
n8dogg
measure the headers at its longest point. Thats at least how much ground clearance you need! Find a lift. It takes me 4-5 hours to install a set with a lift, I'd expect another 2 hours on the ground.
Old Sep 12, 2010 | 09:02 PM
bumble-z's Avatar
bumble-z
Not your average jack stands. Need to get your car up approximately
24".
No big deal. I purchased h/d jack stands from Sears quite a few years ago just for jobs like those.
Good luck.
Old Sep 12, 2010 | 09:04 PM
atmsrus1's Avatar
atmsrus1
Thanks I will check that out.
Wow 6-7 hours on my back would suck
Old Sep 12, 2010 | 09:05 PM
atmsrus1's Avatar
atmsrus1
24".
Good luck.
24" ok Thanks
Old Sep 12, 2010 | 09:16 PM
rpm462's Avatar
rpm462
I did mine on jack stands in my garage and just worked on it with my son a couple hours each day after work. Took me about 4 days doing it that way but I was in no hurry. Not all the time is on your back, you'll also be removing and re-installing things from up top as well. I actually don't think I spent more then two hours total on my back under the car and that includes swapping out the tunnel plate with a thicker ceramic coated one.
Old Sep 12, 2010 | 10:14 PM
atmsrus1's Avatar
atmsrus1
That sounds good, I plan on my son helping me also he just don't know it yet. I found a good write up on how to do it with jack stands and it doesn't look to be to bad. I don't drive mine everyday so if it takes a few days then taht is fine also.
Thanks,
Russell
Old Sep 13, 2010 | 09:42 AM
khafe458's Avatar
khafe458
Thanks,
Russell
I did it on jackstands in my driveway in a weekend. I could have done it faster but really just took my time with everything and had fun with it. Gook Luck with the install.
Old Sep 13, 2010 | 09:53 AM
krzytrain's Avatar
krzytrain
All Aboard!!!
We did mine last week on jack stands. You will need about 24" like stated above. If i would have had all the correct parts we would have been done in about 5 hours, but then again i had a GM mechanic helping me.
What headers did you get?
To Header Installation Question
