larger rear brakes?
Old Sep 13, 2010 | 02:33 PM
tdogg21's Avatar
tdogg21
2017 C3 of Year Finalist
Default larger rear brakes?
has anyone gone with larger brakes in the rear only? i'm not ready to commit to 18 and 19 wheels, but would like to 'fill' the 18" rear wheels a little more. any one tried it yet?
Old Sep 13, 2010 | 04:33 PM
Tom@Zip's Avatar
Tom@Zip
Platinum Supporting Vendor
Hear are some options for rear brakes. There will be a small spacer required for the 13" set and wheels with a "high offset" for the 14" sets.
Feel free to give me a call if you would like any more information.
Tom
1-800-962-9632 ext 240
Click here to see Rear Brake Packages for C5 Corvette
__________________
Zip Corvette Parts and Accessories - Corvettes Are All We Do!
Selling Quality Corvette Parts & Accessories Since 1977
Corvette Parts Catalogs | Subscribe to our newsletter
Corvette Tech Articles | Corvette Parts Blog
Old Sep 13, 2010 | 05:46 PM
c5vetteguy's Avatar
c5vetteguy
2018 C5 of Year Finalist
Baer Eradispeed 2-piece front and rear on 18" magnesiums. Stock size fronts (12.8"), 14" rears. I also put in a heavier brake bias spring which allows for more rear braking force. The car does brake noticeably flatter (and shorter, of course) than before.
Old Sep 14, 2010 | 04:21 PM
tdogg21's Avatar
tdogg21
thanks. that's exactly what i was hoping to see. did you need to make any modifications or use any spacers?
by the way, i love your headlights!
Old Sep 14, 2010 | 04:24 PM
tdogg21's Avatar
tdogg21
Tom
honestly, that's more than i want to spend right now. but i appreciate the options. i have stock mag wheels and i'd like to fill the the rear wheel a little more. would i be able to go with larger rotors or would i have to buy all new everything for the rear? (sorry if that's a dumb question, i'm not very knowledgeable when it comes to brakes) and if i can fit just larger rotors, would i be better off just saving my money and buying the all new 'stuff' for the rear?
Old Sep 15, 2010 | 01:51 PM
Zip Corvettes's Avatar
Zip Corvettes
Are you only doing this for looks, because really you are going to lose some performance with it. You are not going to increase the brake bias to the rear by simply adding a rotor and you really want most of the bias on the front. What you are doing it increasing weight, not just weight but rotating weight which requires power to turn. It may all be neglable to a standpoint, but you are better off staying with what you have and saving up and buying a brake kit later the lighter rotors and better calipers.
Justin
Old Sep 15, 2010 | 03:05 PM
c5vetteguy's Avatar
c5vetteguy
No mods whatsoever to the brakes. The rear Eradispeeds come with the offset bracket needed. The fronts are direct bolt-on. The rear rotors are very close to the wheels, but no clearance problems. The weight of these brakes are supposed to be less than the stock ones because the hats are aluminum. Even if they end up the same weight as stock, more performance without weight gain is a good thing.
The headlights are the HID projector Sun Guns - coming to a JW Motoring near you soon...
Old Sep 15, 2010 | 03:32 PM
tdogg21's Avatar
tdogg21
i am looking to make it look better, but i also would want some performance upgrade as well.i just hate how small the rear brakes look.
To larger rear brakes?
