Yes. The LS7 will work for the LS1/LS6 crank. However, you must use the LS1/6 hydraulics. So buy the flywheel, clutch and PP as a set and you are good to go. Then just buy all the other stuff new from a forum vendor.
By the way, I had to loosen the bellhousing on my 2001 Z06 to get my new LS7 clutch kit in my car. Tried for about 15-30 minutes to get it in without doing that and it just wouldn't go. It is damn tight at the top of the bellhousing and the flywheel is soooo much bigger. Friggin' heavy too, but I do not regret the purchase.
Excellent, that is what i needed to know. Hopefully it will take a little boost I am going to throw at it.
