Master blaster
Old Sep 18, 2010 | 04:02 PM
v1 rot8's Avatar
v1 rot8
Default Master blaster
Has anyone used the master blaster? If so how does it work?
Old Sep 18, 2010 | 04:08 PM
Drumss's Avatar
Drumss
I do not, but a vette buddy of mine owns one and says it's great... I'll probably get one after seeing it in action.
Old Sep 18, 2010 | 04:23 PM
v1 rot8's Avatar
v1 rot8
there add movie clip sure makes it look like it work great. Like to have one, just like to know if it really works as well as it looks like it would
Zorlac's Avatar
Zorlac
Mine should be here next week. I found a used one for $100.
Old Sep 18, 2010 | 04:30 PM
v1 rot8's Avatar
v1 rot8
cool, where did you find it, Ebay?
Old Sep 18, 2010 | 04:58 PM
Zorlac's Avatar
Zorlac
Found it on the C-list
Old Sep 18, 2010 | 05:06 PM
3GenVettes's Avatar
3GenVettes
They work great. Got mine about a year and a half ago. It does a super job with wheels, it really makes drying quicker and easier most of the time. However, if you wash your car on a really hot, sunny day you might not want to use it and stick with micro fiber. That is the only time that the towel is faster or better IMO. And it beat a leaf blower by a long shot.
Old Sep 18, 2010 | 05:22 PM
BHRZ06's Avatar
BHRZ06
I have one and love it, works great for cleaning the interior too, just open the doors and blow the crap out Haven't used a vac since
Old Sep 18, 2010 | 05:34 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
I use it in my shop when I wash cars - best thing since sliced bread! The only thing that I will say about it as a caution, you will need a 20amp receptacle to run both motors. Most residential service has 15amp receptacles, and with an 18amp draw it will pop your 15amp breaker.
It blows heated and filtered air, it works great!
Old Sep 18, 2010 | 08:56 PM
Blew by you's Avatar
Blew by you
Aren't the Master blasters a AC plug in unit you have to drag around the car!?, i use my $89.00 gas leaf blower and it works great! without dragging a cord around catching on the tires!.
Old Sep 18, 2010 | 09:18 PM
3GenVettes's Avatar
3GenVettes
Yes, they are electrical plug in, but the long hose and the wheels on the unit make movement of it extremely simple. The heated air is far more effective than a leaf blower. The velocity of the air is much higher, and I found a leaf blower to be far more awkward to maneuver in small places than the master blaster. Even my small 4HP hand held blaster whips the leaf blower even though it also has a cord.
Old Sep 18, 2010 | 10:39 PM
v1 rot8's Avatar
v1 rot8
Thanks guys, the first time I seen one of these I thought "you got to be kidding me", now I am thinking I want one.
Old Sep 18, 2010 | 10:54 PM
4 KRUSIN's Avatar
4 KRUSIN
I have one and have used it quite a bit. No, it is not faster than drying with a towel. Yes, it's safer. Interestingly, you need a good wax base on your car for it to be effective at all. It works well with my Vette, but not so well with my F150 because I haven't waxed it properly. I haven't tried it on my interior, but will after reading this thread.
Old Sep 19, 2010 | 10:05 AM
HMannini's Avatar
HMannini
Cruise-In X Veteran
St. Jude Donor '09
I thought the same thing and I was using a leaf blower to dry my car but I bought the Blaster and haven't looked back.......I absolutely love it!!!! It was a pain storing it until they came up with the wall hook, now I have my drying area set up conveniently in my garage. It takes half the time to wash/dry my car as it used to.
Old Sep 19, 2010 | 12:30 PM
paul82146's Avatar
paul82146
Default Master Blaster
Love mine - Never use anything else to dry her.
Old Sep 19, 2010 | 01:10 PM
MarkyMarkGTM's Avatar
MarkyMarkGTM
I have had mine for about a year and overall I like it but there are a few things that if I had known before buying, I probably wouldn't have. The major dislikes for me that I didn't think about when buying would be...
1. I would not say that you can dry a vehicle with this unit alone UNLESS it has a very good coat of wax on it. When the water beads up it is easily pushed off the car with the air force but if you don't have good beading the water will just sort of spread out and dry, leaving behind trails of dried water that you can see and look horrible.
Even if the car is waxed properly it is very time consuming to dry with just the blaster. I find that I combo the blaster with microfiber for the best/ fastest results.
2. The power usage, as one member pointed out, is a lot and most homes that I have used the blaster at have trouble running both motors without popping the breaker. Sometimes if I shut off everything else on the circuit I can run the blaster long enough to dry my car. More often though I start with both motors and when the circuit pops just change over to the one motor setting.
Those are the two major fails with this product but in addition to that my hose started tearing near the part where you hang on (right where the attachment screws on) and this was after a few months of ownership. I just wrapped it in duct tape and it's fine.
Also (totally operator error) I find that the on/off toggle switches are easy to accidentally hit when the unit is not in use. I don't know if it is how I store it, how I handle it, or what, but on multiple occasions when I plugged it in it was already on and started blowing. The hose whipping around could cause damage really fast and I have learned to always double check the position of the toggles before plugging it in. Again, this is my mistake so I can't hold it against the product but it is part of the design that I don't like. I could be the only one on this though.
This product is absolutely great when it comes to cracks and crevices, think engine, wheels, wheel wells, door jambs, mirrors, etc. The promotional video is good at highlighting this aspect. The heated air (main reason I bought it) is also great and helps out the drying process immensely.
I was using compressed air and a towel before and honestly I probably would have just stayed with that method if I had know more about this product. Now that I do have it I use it and like it, but if you are already using either a leaf blower or compressor to dry your car, don't expect a world of difference. Overall it is a nice product and if you can find one for cheap, all the more reason to get it.
Old Sep 19, 2010 | 01:38 PM
v1 rot8's Avatar
v1 rot8
Thanks a lot Mark, good info there, I have been looking at ebay and C's but have not found one yet
To Master blaster
Old Sep 19, 2010 | 03:07 PM
Shirl's Avatar
Shirl
2025 C8 of the Year Finalist - Modified
2021 C7 of the Year Finalist - Unmodified
Toro Electric leaf blower.
Old Sep 19, 2010 | 03:15 PM
TIKTGTR's Avatar
TIKTGTR
Sure its not any better than my Echo blower Just sayin
Old Sep 19, 2010 | 03:39 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
I use my electric leaf blower and it works very good - Expensive piece but it probably is convinient!
Thanks,Matt
