2001 Corvette Key
Old Sep 18, 2010 | 06:44 PM
ricknyc23's Avatar
ricknyc23
Default 2001 Corvette Key
i am trying to order a replacement key online for my 2001 corvette and they need to know the ohms on the chip. Since i do not have a tester, would any of you guys know if the ohms are the same for all 2001's and if so what are they? If each vehicle is different do you know where i can go to get the ohms on my key measured?
thanks....
Old Sep 18, 2010 | 06:57 PM
87SAM's Avatar
87SAM
There are 15 different resistor values for the key pellet. Anyone with a DMM could measure your key. For my C4, I just went to a local key shop and they hooked me up with a new key on the spot.
Old Sep 18, 2010 | 09:09 PM
Just take one of your keys to a locksmith and they should be able to tell you exactly what value the key is. That or go to your dealer.
Old Sep 18, 2010 | 10:58 PM
coolarrow's Avatar
coolarrow
St. Jude Donor '12
Go to Harbor Freight and buy a multi-meter for under $4.00 (even less if you catch a sale). Measure your ohms, go to eBay and order key based on ohm reading. Have key cut at any key shop. Then put the MM in your toolbox. Did this myself about a year ago.
Old Sep 20, 2010 | 05:27 PM
bighank's Avatar
bighank
Default Ditto amd the blank kye of fleebay is a lot cheaper than dealer or locksmith
Got my blanks on fleebay after measureing with a DVOM. Auction site has venders which equate resistance to a number. Then get it cut at a real locksmith for less than $2. Shop around. Some robbers here wanted $10 to $20 to CUT the key. BS. Get 2 and have a spare.
Old Sep 20, 2010 | 08:48 PM
ricknyc23's Avatar
ricknyc23
thanks for the replies guys. i will pick up he meter from harbor frieght
Old Sep 20, 2010 | 09:58 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Here is a list of the key numbers.
To 2001 Corvette Key
