I have a rattle noise from the engine when I push the gas pedal a little bit while driving, (so little that the car does´t accelerate).
I also have the sound when I´m in neutral and revving up to about 1200 rmp.
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
You might want to make this into a video file and post it on YouTube. Myself, I will never download an unknown file from a brand new member. Too much risk of a virus.
That being said, what you are describing sounds like valvetrain noise.
Have you had a significant other in the drivers seat running the RPM while you are poking around(carefully) under the hood trying to locate the source of said noise?
Or........ as I usually do wait until it gets really bad and breaks and then its a "no brainer" as to what's the noise source!
