negitive feedback ?
Old Sep 20, 2010 | 01:35 AM
One Nut's Avatar
One Nut
Default negitive feedback ?
I'm thinking of buying a set of tires from jfranklinz06 he has not been a member for very long Does anybody have any info on him thanks just trying to watch my doe. I am sorry if this offends anybody.
Old Sep 20, 2010 | 01:39 AM
0331MARINE's Avatar
0331MARINE
From: You know your drunk when you swerve to miss the tree then you realize its your air freshener! Covington Ga
Have someone around him go check them out for you.
Old Sep 20, 2010 | 02:47 AM
00Corvette's Avatar
00Corvette
Check out his paypal history...if he's confirmed and verified, you should be able to see how many transactions he's done.
Get close up pictures
Old Sep 20, 2010 | 02:27 PM
hotwheels57's Avatar
hotwheels57
trust your gut instincts!!
Old Sep 20, 2010 | 02:37 PM
BobAruba's Avatar
BobAruba
Good option Chris has there.
Steve, you're a serious buyer. No seller should be offended.
I know I would not be if it were me.
Be cautious and good luck on your purchase.
Semper Fi!
Huurraah!
Bob
Old Sep 20, 2010 | 03:26 PM
jrprich's Avatar
jrprich
Make sure you get pics of all 4 DOT labels so you can tell how old they are.
First locate the letters "DOT" on the sidewall of the tire. Nearby will be the DOT code. DOT codes are 10 to 12 digits long. BTW the digits can be numbers or letters.
The first 2 digits are a code for the manufacturing plant.
The next 2 digits are a code for the tire size.
The next 3 or 4 digits are a code for the type of tire.
The last 3 or 4 digits are the date code. The format is week/week/year/year or week/week/year. These are always numbers.
Starting in the year 2000, the date coding used was 4 digits. That means the largest number you should see for the year is 09. Before 1999 the format was 3 digits. 1999 and 2000 are transition years, so you will find both 3 and 4 digits.
The date code only has to be on one side – and it is permissible for there to be a partial DOT code, so long as one side has the complete code.
To negitive feedback ?
