F45 Suspension
I have the F45 and was thinking about lowering it. I posted here asking if there would be any issues and the replies were No problem with the F45 lowered.
I did quite a bit of reading on this a few years ago. Some said the F45 might have issues with lowering. Well...on my ex-98 with F45, I fully lowered it (also cut bushings), and I never had any issues, except that the shocks got a lot firmer (the sensors will think the shocks are compressed, and cause them to firm up). I have the F45 again on my current 01, lowered it again with cut bushings. So far so good. I did extend the shocks a bit to prevent them becoming too firm this time.
Hope this helps
You can see on this pic how low cut bushings will make your Vette. There was a finger's width between ground and the front plastic bumper piece.
Hope this helps
Many Thanks to all for the speedy replies and should be lowering it before I put it away for the winter. Thanks again Danny DevilDog II where did you get the simulators from and was it hard to put them on ?
-Alex
Hope this helps
Hope this helps
How do you extend the shocks as mentioned and what is meant by cutting the bushings?
Check my avatar....F45 lowered on stock bolts.....14 years, 25,000 miles, and still seems to be OK.
