HELP... The MOD BUG BIT ME BAD...
Old Sep 20, 2010 | 11:07 PM
TN Vette's Avatar
TN Vette
Default HELP... The MOD BUG BIT ME BAD...
As soon as the car gets back from the body shop, I plan on installing the following parts waiting at home in the garage... if not more...
TPIS LT headers
Random X pipe with high flow cats
Z06 Ti catback exhaust
GMPP Red wires
NGK TR5's
stainless C5 exhaust tip accent plate
Coolant change
Oil change
Column Lock Bypass
Cold air kit
I may have forgotten something....
Tell me Doc's, is it bad?
Old Sep 20, 2010 | 11:13 PM
4cRanch's Avatar
4cRanch
Yea, it looks like you are terminal You're only chance of remission would be an immediate tune after those mods.
Old Sep 20, 2010 | 11:15 PM
TN Vette's Avatar
TN Vette
shhhh... don't tell the wife, that is on the "to do" list soon...
Old Sep 20, 2010 | 11:24 PM
It's not terminal, but so far there seems to be no cure for the mod bug.
Old Sep 20, 2010 | 11:25 PM
MawneeC5's Avatar
MawneeC5
This forums is a carrier for this virus. I bought my Z06 and told the wife " I probably wont mod this one" ....two weeks later I"m ordering the parts for a cam swap
Old Sep 20, 2010 | 11:31 PM
TN Vette's Avatar
TN Vette
The first thing my wife asked when I bought the car was.. " are you going to put $30k in this one too?"
I paid $15k for the 2000 Mustang GT I had and then put about that much in mods over the 7 yrs I had it. Boost, exhaust... tune, rims, tires, suspension, yata yata yata...
Old Sep 20, 2010 | 11:37 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
You got a great start on the slippery slope of no return on modding
Old Sep 20, 2010 | 11:56 PM
BHRZ06's Avatar
BHRZ06
looks like the tip of the iceberg lol
Old Oct 9, 2010 | 09:09 PM
TN Vette's Avatar
TN Vette
Default The downward spiral has begun...
http://forums.corvetteforum.com/c5-t...went-well.html
Old Oct 9, 2010 | 09:50 PM
RedSoxFan's Avatar
RedSoxFan
You're fine, don't worry about it. If stuff starts piling up you might want to consider an addition to your garage, but your condition sounds perfectly normal to me.
Old Oct 9, 2010 | 09:54 PM
ztheusa's Avatar
ztheusa
Veteran: National Guard
I'd add a skip shift eliminator, or program it out.
Old Oct 9, 2010 | 10:06 PM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
Nice job on the TPIS install. That's a nice set-up.
Old Oct 9, 2010 | 10:07 PM
81c3's Avatar
81c3
So what cam are you thinking about?
Old Oct 9, 2010 | 10:36 PM
Monkey D. Luffy's Avatar
Monkey D. Luffy
There is NO cure. The car is never done, there will always be that 1 more thing.
Old Oct 9, 2010 | 11:21 PM
TN Vette's Avatar
TN Vette
Default Thanks
I wasn't sure if I could do the Z06 Ti swap safely, but found a way of lifting/supporting the car safely.
Old Oct 9, 2010 | 11:42 PM
KorbenDallas's Avatar
KorbenDallas
Doesn't look too bad to me... when you start swapping heads, cam, gears, wheels/tires things get expen$ive fa$t!
Old Oct 9, 2010 | 11:52 PM
TN Vette's Avatar
TN Vette
I have another set of rims already, just shopping for tires as soon as the current ones wear out.
To HELP... The MOD BUG BIT ME BAD...
