AMP/IPOD2CAR install issue.
Old Sep 22, 2010 | 04:49 PM
--Z06--'s Avatar
--Z06--
Default AMP/IPOD2CAR install issue.
My high horsepower brethren,
OK. I have a PAC harness and converter for my amp from the factory HU. I just installed the IPOD2CAR interface, works great BTW, but does not charge my iPhone4. Also, after I installed it, my amp started cutting in and out until finally quit. I have checked and rechecked every connection and found none to be loose or damaged. I plan to tear it all apart tomorrow morning when it is cooler out and put it all back together AGAIN in hopes that I just missed some thing or jarred some thing loose.
Any ideas? Could the IPOD2CAR interface be causing issues with the PAC harness/converter?
I appreciate any input guys.
-Pete
Old Sep 22, 2010 | 08:27 PM
Double D Mods's Avatar
0Double D Mods
Former Vendor
St. Jude Donor '12-'13
Hey pete
which ipod2car kit did you get?
the new pxdp kits will charge an iphone 4
if you dont have a newer version I sell the new cables that will allow it to charge.
the aoem-vet1 and the pxdp can both be used at the same time
Old Sep 22, 2010 | 10:29 PM
YLO Z06's Avatar
YLO Z06
2023 C5 of the Year Finalist - Modified
I have both installed on my car and they work fine together. I bought my ipod2car interface from c5 BearsFan .
Old Sep 23, 2010 | 07:20 AM
--Z06--'s Avatar
--Z06--
Ill check the version number on the unit today.
Old Sep 23, 2010 | 12:26 PM
--Z06--'s Avatar
--Z06--
1.4.1 on the ipod2car. Got it all working now, my ground for the amp was not secured.
One more question. Should my CD player be working? It reads disc 1 track 1 then goes 1:00 then to 2:00 no sound.
Old Sep 23, 2010 | 09:48 PM
YLO Z06's Avatar
YLO Z06
The stock radio has a "CD/AUX" button on it. When the ipod is connected, the radio will default to the ipod, where it will display "Disc 1Track 1". You can select the next track by hitting the forward "Seek" button on the radio - the display will then read "Disc 1 Track 2". If you want to listen to a CD, hit the "CD/AUX" button and the radio will switch to the CD and begin playing that. The "CD/AUX" button cycles between the CD and the ipod.
Old Sep 24, 2010 | 06:56 AM
--Z06--'s Avatar
--Z06--
I have a CD and a seperate AUX button.
Old Sep 24, 2010 | 09:18 AM
--Z06--'s Avatar
--Z06--
Oh, and the inside of the C5 dash is a terrible place for big hands! I have tiny little cuts all over both hands! WEAR GLOVES! I wish I had been wearing maybe doubled up rubber gloves to protect my hands. It's like the death of a thousand cuts in there!
To AMP/IPOD2CAR install issue.
