c5 steering play
Old Sep 23, 2010 | 11:02 AM
MadMurdocks's Avatar
MadMurdocks
5th Gear
Default c5 steering play
ok, i bought a 2000 c5 with 85k. The steering wheel has atleast one inch of play, and its a bit scary at 70 mph. i tightened the hell out of both bolts on the column, no help.
Is there an adjustment in the rack or something ?
appreciate any ideas.... thanks, Bob
Old Sep 23, 2010 | 11:23 AM
Mark C5's Avatar
Mark C5
St. Jude Donor '08-'09-'10
There is a steering preload adjustment in the rack but with that much play I'd check out the rest of the suspension before I worried about that. Also, you say you "tightened the hell out of both bolts". Did you torque them to 25 ft/lbs?
One more thing; you may want to consider changing your screen name if you really do want helpful advice on this forum.
Old Sep 23, 2010 | 11:41 AM
MadMurdocks
5th Gear
thanks mark, thats interesting ...so this adjustment can be found on top of the rack or something ??
I did not use a torque wrench, but I put enough on those bolts that my bicep hurt the next day.
My other thought is the upper part of the column, where there is some kind of coupler?? When I grab that w my hand and spin it left and right real quick, I can feel that slack between there and the steering wheel...make sense??
Old Sep 23, 2010 | 02:30 PM
WvCorvette's Avatar
WvCorvette
One more thing; you may want to consider changing your screen name if you really do want helpful advice on this forum.[/QUOTE]
Old Sep 23, 2010 | 02:32 PM
JW Motorsports's Avatar
JW Motorsports
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
What's up with the name?
Old Sep 23, 2010 | 02:33 PM
redrckt97's Avatar
redrckt97
sounds like maybe the "test drive = junk".
To c5 steering play
