LED rear tail lite problem...
Old Sep 23, 2010 | 06:32 PM
basicstrategy777's Avatar
basicstrategy777
St. Jude Donor '11-'12-'13-'14-'15-'16-'17,'20, '21,'22, '23
Default LED rear tail lite problem...
The right most tail lite appears to work perfectly when viewed up close, but as you move back, say 30 feet, it is definately dimmer than the other 3 lites. In short, at a distance it is dim and up close it appears the same as the other lites.
Anybody have an idea what the problem might be ?
I hope I can find a replacement lite if I need one.....hate to buy 4.
777
Old Sep 23, 2010 | 07:26 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
It would help if you told us what lights you have, All are not created equal.
Old Sep 24, 2010 | 08:48 AM
hoosiervette's Avatar
hoosiervette
St. Jude Donor '14-'15-'16
Can they be put in upside down, thus changing the angle at which they are viewed? I'm not sure if they will fit upside down.
Old Sep 24, 2010 | 09:00 AM
basicstrategy777
I bought them from Brian@FI Performance out of Stamford CT. in 2008 ; he use to advertize here. I cannot reach him. What I was told is they are from China and made by a company that produces LED systems for trucks. They appear to be good quality and have 32 bulbs per lite. I'll keep looking for specifics. I thought an LED light person might be able to shed some light on the electrical problem.
Good thought on the upside down....I will flip it and see.
777
Old Sep 24, 2010 | 09:03 AM
JW Motorsports's Avatar
JW Motorsports
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
No you can't install it upside down.
If you need a new one we sell them for $75 each. You don't need to buy 4 of them.
Old Sep 24, 2010 | 09:18 AM
basicstrategy777
JW....That is good to know.
I'd like the lite not to look different from the other 3. Do you have a picture of the lite you are talking about looking at it directly from the rear ?
777
Old Sep 24, 2010 | 09:26 AM
JW Motorsports
Banned Scam/Spammer
http://forums.corvetteforum.com/c5-p...-anywhere.html
They're the same ones Brian sells. We have the same supplier.
Old Sep 24, 2010 | 10:24 AM
basicstrategy777
JW......those look like the ones. This is good to know. If I can't fix mine I will order from you. They are very good lites and I like them.
777
Old Sep 24, 2010 | 01:36 PM
You might try contacting forum member Theradioflyer and see if he can give you some suggestions. He is very good with the LED stuff.
Old Sep 27, 2010 | 11:26 AM
basicstrategy777
I replaced my clear side markers ( probably should not have spent the money as the ones I took out look pretty good). Checked the LED rear tail lite I had the dimming problem on and yes it was installed upside-down; the connection was also corroded and I cleaned up the connection. Tail light now works good. Hopefully that was the problem, you know how electrics are.
777
Old Sep 27, 2010 | 11:34 AM
TheRadioFlyer's Avatar
TheRadioFlyer
Supporting Vendor
yes, they will, just not very well.
It IS possible to install them upside down. One of the guys in my car club had his upside down until we fixed it before a road trip.
Old Sep 27, 2010 | 06:31 PM
Nick1's Avatar
Nick1
I had a similar question regarding fixing them. Suppose one or two of the individual lights in one unit are dim or out. Is there a diy for this? Thanks
Old Sep 27, 2010 | 09:43 PM
Vette Dog's Avatar
Vette Dog
If you know how to solder very well, know how to position the square LEDs, and can purchase a few extra of the same LED the supplier uses....then yes you can DIY. Otherwise send it in to JW and one of his fantastic techs will be more than happy to help.
Old Sep 27, 2010 | 10:03 PM
TheRadioFlyer
Supporting Vendor
If one of the LEDs go out, it's usually a failed LED. If there's 2 or more in an area, it's usually a failed resistor. Both of which can be replaced easily.
Old Sep 27, 2010 | 10:46 PM
Vette Dog's Avatar
Vette Dog
I have never come across a failed resistor to cause two LEDs out in a row. Usually the first failed LED will drive up the resistance reducing voltage on the pos of the next LED in sequence. But I have also seen 2 in a row go bad, sometimes the board itself with a bad run.
Old Sep 28, 2010 | 04:04 AM
tstar's Avatar
tstar
Or a bad connection on the PCB... ran into that a few times.
Anywho I think they were talking about installing the connector in backwards not the physical light assembly, that would be pretty obvious I'd think AND it is marked "TOP"
Old Sep 28, 2010 | 05:06 AM
Yello95's Avatar
Yello95
St. Jude Donor '11
777
I'm sure it can be fixed or you can find a replacement light...I bought 2 complete sets incase I needed spares for ones that failed
To LED rear tail lite problem...
