Brake reservoir question
Old Sep 23, 2010 | 06:56 PM
kingrobby25's Avatar
kingrobby25
Default Brake reservoir question
So I changed my brake fluid then left for 6 months, came home and the brakes are really mushy. I've done this many times over the last 5 yrs and never had this happen.
Looked at the fluid and it is very murky already, even though the fluid only has like 100miles on it. I did notice that the rubber seal boot thingy under the cap has a hole at the bottom. I think this allowed water to soak into the brake fluid while it was sitting.
Changed fluid and the brakes are good again, but now I need to get a new rubber thingy. Dealer says I can only buy the whole assembly. any thoughts??
Old Sep 24, 2010 | 02:24 AM
kingrobby25
ttt
Old Sep 24, 2010 | 04:06 PM
robsc501's Avatar
robsc501
Hi There,
The dealer is correct. Heres the p/number 18060785.My dealer says $384.20. for the m/cylinder.Gene Cully may provide you with a better price.
robsc501
Old Sep 24, 2010 | 04:27 PM
STL94LT1's Avatar
STL94LT1
PM me your name and address and I will send you a rubber seal for free. A savings of $384.20.
Old Sep 24, 2010 | 05:52 PM
CHJ In Virginia's Avatar
CHJ In Virginia
Go to your local NAPA auto parts store. You can purchase the cap seal for $1.98 + tax. Screw the stealership.
Old Sep 24, 2010 | 11:30 PM
robsc501's Avatar
robsc501
Hi There,
What is the napa p/number?
robsc501
To Brake reservoir question
