[Z06] Mallet cam specs??
Sep 24, 2010 | 02:56 PM
Mallet cam specs??
How can I find the actual cam specs on a Mallet cam?
Here are the #'s stamped on it...
242547
Etched on the end...
LS1 3726 3728 D3575-04
Inquiry calls to Mallet fail.
Sep 24, 2010 | 03:06 PM
St. Jude Donor '10
Call up Comp, they can look up the serial # in the computer and provide specs
Sep 25, 2010 | 06:56 AM
I didn't know it was a Comp cam...thanks, I'll call them.
Sep 27, 2010 | 11:29 AM
Quote:
Originally Posted by
mAydAy121
Thanks for the heads up!! I called Comp this morning.
I've got the specs on this cam...
Lobe profiles are 3726/3728
Serial # D 3575-04
Core C54-11A
Spec card #06751604
Grind # LS1 3726/3728 HR114.0
281/285 adv
232/236 @ .050";
.595/.601" lift;
114 degree LSA, ground with a 114 degree intake center line.
Mfg date 11/11/2004 for Mallet Cars.
Sep 27, 2010 | 11:48 AM
I have that same cam on a 113lsa. Great cam. Put 415 to the rear tires with stock heads.
Sep 28, 2010 | 09:04 PM
I'm thinking of using this cam in a CARBED, LM7 5.3L topped with either Patriot CNC or reworked LS6 243 heads...swap project going into a '67 Chevelle.
