[Z06] Not very happy
Old Sep 26, 2010 | 09:03 AM
CORKONE's Avatar
CORKONE
Default Not very happy
Recently purchased 2003 Z06 with 8100 miles. Since purchase (about 6 weeks ago) I have had both window regulators fail & now the driver side door lock actuator. Total cost for repairs about $1500.00. Can't say I am favorably impressed at this point. This is my 3rd Vette, 1st one was a new 65. Cool car but like this one, always something needed repair. 2nd Vette was a 93. Best yet, absolutely flawless performance the entire time I owned it. Am I to believe the problems I have had with this car are normal or am I just having a run of bad luck? If this is normal, the car will be gone ASAP.
Old Sep 26, 2010 | 09:22 AM
ipuig's Avatar
ipuig
St. Jude Donor '09
You are having a run of bad luck, the stated price for the repairs is ridiculously high and BTW the window regulators are repairable if the motor still works. I just repaired my passenger side window regulator for the cost of some new SS cable (< $20.00).
Old Sep 26, 2010 | 11:00 AM
Its Bruce's Avatar
Its Bruce
It's a 2003 with only 8100 miles. Regulators and actuators like to be cycled to keep from seizing up and yours haven't. Did you do the BFH trick before completely replacing them?
Old Sep 26, 2010 | 12:06 PM
~Josh's Avatar
~Josh
Banned Scam/Spammer
This website will save you a ton of money if you research here before taking your 'Vette for repairs. The C5 will also let you read any trouble codes right from your odometer readout.
In the end, your C5z will be remembered as a must-have chapter.
Old Sep 26, 2010 | 12:19 PM
johnnytaboo's Avatar
johnnytaboo
Just stick with it for now man. The guy who owned my car before me hardly ever drove it. In the first 2 months I got column-locked.....twice! After everything though, I feel I've grown closer to my car, and thanks to this forum, I think I will be able to prevent some of the common problems, or at the very least, be prepared when they hit.
It's been 6 months and almost 10K miles of daily driving with no further problems since the column lock fiasco. Stay the course!!!!!!!
Old Sep 26, 2010 | 02:18 PM
James92's Avatar
James92
I've owned my '04 for almost 2 years now, no problems. 45k miles on it, I've put on 10k of those miles.
Old Sep 26, 2010 | 02:28 PM
J Z06's Avatar
J Z06
My '04 has been the most reliable/trouble free performance car I'd ever owned. So far, tires and oil changes are the only $ I'd spent on it. Original brakes at 50k miles too. You're having bad luck...it'll pass.
Old Sep 26, 2010 | 03:07 PM
79inSD's Avatar
79inSD
I have had mine for about 3 years now and my window regulators have gone out about 4 times. Luckily I am still under warranty. Other than that I have had no problems with the car.
Old Sep 26, 2010 | 03:39 PM
TXGS507's Avatar
TXGS507
Hey **** happens..you chose to shell out $1500 for the regulators, accuator(crazy)? Yes, you should probably go back to the C4... I'm sure you had no issues with it...Opti, weather stripping, creaks,rattles... gotta pay to play... just my .02
Old Sep 26, 2010 | 04:58 PM
CORKONE's Avatar
CORKONE
Thx to all of you for your kindly remarks.
What is the BFH trick?
As to the cost of the repairs...absolutely a rip off ...done by the local
Chev dealership.
Go back to the C4? I don't think so. It was a very reliable car with absolutely no issues & I expect this car to perform equally as well.
The driver window had a "stretched cable" (dealer description). The pax window operation was very intermittent. Door lock actuator would unlock with FOB or lock switch but would not lock with either one.
Old Sep 26, 2010 | 05:18 PM
Its Bruce's Avatar
Its Bruce
BFH
Step 1 (optional): Remove interior door panel.
Step 2: Hit window regular with Big Friggin Hammer while actuating.
Old Sep 26, 2010 | 05:55 PM
MawneeC5's Avatar
MawneeC5
Originally Posted by Its Bruce
BFH
LOL
I have the same issue with my passenger side window. Just havent had a chance to open it up and check it out yet. I wasnt suprised though its an 8 year old car with 25k miles, I dont imagine that window was used alot.
Old Sep 26, 2010 | 06:01 PM
wildwall's Avatar
wildwall
The c5's have some weak points, and they are electronic related. They are inexpensive to fix if you seek the solutions posted on this forum. $1500 was spent at the dealer?
Problematic issues:
column lock- get a bypass modue asap- $50
abs computer- absfixer.com
window and door lock relays - you can buy the relays for a couple bucks and replace the bad ones on the door logic boards
The main thing that will screw you up and happens to EVERYONE sooner or later is the column lock. Order a bypass module tonight and put it in right away. This can save you being stuck and spending a couple grand getting towed and having the dealer do a fix that still won't fix the problem. The fix involves putting in a module that tricks the computer into thinking the column locks and unlocks. The column actually is never locked again, and the steering wheel can be turned with the car off.
The other issues may or may not happen, and this website will make the fixes inexpensive and easy- and better than when the car was new. Most of us have had our cars for years and lived through these problems and fixed them for very little money.
Enjoy!
Old Sep 26, 2010 | 06:44 PM
apriliacati's Avatar
apriliacati
Problematic issues:
Enjoy!
Do what he said, DO NOT WAIT, it must be done NOW.
Old Sep 26, 2010 | 09:39 PM
CORKONE's Avatar
CORKONE
The column lock issue has already been addressed. (Previous owner)
As for the door lock problem, it is the actuator that has failed, not the relay.
Had I known about the BFH fix before taking it to the dealership, I would have given it a try. The dealership parts dept. told me they keep a large inventory of "door lock actuators" & "window regulators". Hmmmm I wonder why? Maybe the BFH principle should be applied to the individual in charge of parts acquisition. Maybe then he/she would get the msg. that the parts have a design defect & perhaps they should seek a new supplier.
Old Sep 26, 2010 | 10:09 PM
KCvetteowner's Avatar
KCvetteowner
http://www.ronjpics.com/Corvettestuff.htm#DCM
save to bookmarks....good stuff
Old Sep 26, 2010 | 10:14 PM
CORKONE's Avatar
CORKONE
The drivers window made a loud grinding noise. I was told the cable had stretched & was the source of the noise. The passenger window operation was intermittent. No unusual noise, just would not work sometimes. You could hear the relay but no movement of the window.
To Not very happy
Old Sep 28, 2010 | 11:38 AM
HUSKER-Z's Avatar
HUSKER-Z
BFH
Old Sep 28, 2010 | 12:40 PM
spdislife's Avatar
spdislife
04 Z with 28,000 miles and no maintainence issues. Just changed the original brakes out for a HPDE event and they were still at 50% or so. Sounds like bad luck to me.
Old Sep 28, 2010 | 03:13 PM
zeevette's Avatar
zeevette
The only time my car's ever been to a dealer was for the column lock recall. I've never had a lock problem in my 8 years of ownership, but after all the histrionics regarding CLB, I bought one. I've yet to install it, but maybe this weekend..... Is it really that common of a problem? Or is it internet hype?
