[Z06] driver window and driver memory seat issues
This is the closet I could find in my searching....
http://forums.corvetteforum.com/c5-z...y-seats-2.html
I'm having two issues and I'm curious if it could be battery related?
1) Driver window will not go without repeated hits of the button. Every once in a while it will go up with no fuss, but maybe 1 out of 20 times. It does always go up but it's like it gets stuck even though it's not.
2) Driver memory seat doesn't always return to it's set position. I may have to hit the button for that a few times to get it to return.
My car is a 04Z and it is pretty much my DD. I don't drive it in the rain but here in TN it doesn't rain all that much so I get to drive it say 5 days out of a week. I've checked the codes recently and saw a loss on communication with left door or something like that. It was a history code and when I cleaned the air filter(whole different story) I got a CEL and pulled the codes then reset them once I knew what they were. I figured a history code would pop back up if it became an issue again.
Has anyone found a simple solution? I may end up just leaving the seat easy exit off, but I don't want to kill the seat bolster by getting in and out. And, what about the window. I'm curious if anyone has seen both problems. Sorry to
but I would like to get these fixed and through my searching I didn't see where anyone had a Eureka moment.Thanks!
