From: Out of Site...Out of Mind. Corvette: anything else is just transportation.
St. Jude Donor '09 thru '20
I think, all you have to do is hold both lock/unlock buttons down untill the car horn sounds, then it's set. If it doesn't, the fob's battery might be dead.
Good luck.
Programming Transmitters
1. Turn the ignition to ON.
2. Turn the radio to OFF.
3. Press the RESET button in order to clear any IPC warning messages.
4. Press and release the OPTIONS button on the DIC to scroll through the display options until the IPC display is blank.
5. Press and hold the RESET button for 3 seconds.
6. Press the OPTIONS button until FOB TRAINING message is displayed.
7. Press the RESET button in order to begin the programming sequence. The message HOLD LK + UNLK 1ST FOB will be displayed.
8. Simultaneously press and hold the LOCK and UNLOCK buttons on the first transmitter for 15 seconds. The IPC will indicate when that transmitter is programmed and when to proceed to the next. Repeat this procedure for each additional transmitter or press the OPTIONS button to exit.
I have a 1998 that I purchased a new fob from a forum vendor. I have tried this procedure several times and cannot get the DIC to display the "FOB TRAINING" message. Will be taking the car into the dealer shortly on another matter and going to have them look at it then.
Another thought,,,Check the battery. 1.might not be in there,,2.many are shipped with a little plastic shield to save the battery,,3.it might be dead !! Just something else to check!!!
thanks for all the info but i get readings from the tire pressure sensors and the remote sends out a signal any other suggestion i am thinking it may be the reciever for the fob
The tire pressure sensors and the FOB use the same receiver. You never answered the questions about the FOB.
If the tire pressure sensors are reading and when you do the programming procedure the DIC cycles to the FOB TRAINING page and the FOB is not accepted, the FOB is not sending out the correct signal.
I would try changing the FOB battery and if that doesn't work, the FOB is bad. Go to the next Corvette event in your area and someone should be willing to let you try programming their FOB to your car as a proof.
