Headlights go up on first flip of the switch and I have the grinding noise.
1st Gear
My headlights are making the grinding noise. I've purchased the headlight kit with the metal gear and I'm about to go out and install it but I have another question. When I first bought the car (it only had 15,900 miles on it when I got it) when I flipped the headlight switch up one position the head lights stayed down and I'm assuming that some type of running lights came on. When I flipped the switch up to the second position then the headlights would flip up. Now that the lights are making the grinding noise when I flip the headlight switch up one position the headlights pop up. Is there something else wrong with this mechanism besides the plastic gears? And is there something else that I have to do to this to fix it? I've read the how to fix the headlight post in here with all the pictures (I think posted by patches, really good stuff) and he didn't mention that problem at all. Any light that somebody could shed on this would be greatly appreciated! Thanks in advance!
Do a search on headlamp motor rebuilding also check out the sticky in C5 General for all I know...click. You'll need to R&R the motors and replace the damaged gear with a brass gear. Or buy new motors from discounter like Gene Culley.
i just read a thread about this and even though i don't have the knowledge to explain it correctly, it appears that when you fix your gear problem your headlight buckets will work properly.
St. Jude Donor '08-'09
Question, yea i dont drive my vert at night never have,
but when i flip the switch to have the headlights come up, it usually takes me to do it twice, should i worry?
